Parts swapping - Chevy D60 to F*rd D60??
Discussion in 'The Garage' started by Greg72, Jan 13, 2006.
  1. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    I'm considering swapping over to a F*rd front axle (HP '78/'79 style) to allow me to use the Doubler kit I've got (also F*rd version)
    If I wanted to, could I steal all the "outer" parts from the Chebby axle and bolt them on (knuckles, 35-spine outers, nice Warn Premiums, spindles, rotors, calipers, caliper mounts). To my understanding, the outers are supposed to be pretty interchangeable.....??? This would allow me to also keep my high steer arms intact (though I think I'll need to re-think my ram mount, since there'll be a pumpkin in the way!! :D
    I could sell the Chevy D60 "as is" but I doubt anyone wants to pay extra for the beefier stuff I put onto it...
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yep. You have to swap everything from the inner Cs out. stub axles, knuckles, breaks, etc. But it is doable. I was planning to do this when I first got my HP 60 but the Ford parts needed to be replaced and it made no sense to sink money into the Chevy 60 with Ford outers when I was just going to sell it. At this point I wish I had swapped and had a Ford HP with Chevy outer parts.
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Im pretty sure that all Dana stuff swapps out. Ford's have 35 spline outers stock I believe.
  4. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    The only stock 35 spline outers are Dana 70s from the 70s. Ford uses 30 like Gm and dodge.
  5. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    What advantage does the gm stuff have over the ford? (other than the upgraded parts greg mentioned)
    I have heard about ford knuckles being weaker, but have not heard much to support these hearings. The dedenbears are also an option.
  6. b454rat
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    I can think of one reason, running 15" wheels. Hear it can be a pain to run them of Ford. I thought about this when I do mine, but I already bought the calipers.....and already have 16s.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    15" rims. Availabilty of brake kits(can't find a 1/2 or 3/4 ton kit for my HP 60 right now). Stronger knuckles(casting is thinner between the spindle mount and the upper kingpin than it is on the Chevy/Dodge setup). Chevy knuckles have a higer tie rod mounting location if my memory serves me.
    Fords have 30 spline outer shafts as well but they are different shafts. They are slightly shorter. Thus why I said those have to be swapped as well. GM and Dodge have slightly longer stub shafts.
  8. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    ford also used 5 smaller studs to hold on the spindle compared to chevys 6 studs that are larger 1/2-9/16 just use the correct inner shaft and the outer to match the brand of outers.just did the ford outer swap to the chevy axle.
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I believe the spindle studs are the same size. Yes there are only 5 vs the 6 of the Dodge and GM version. Never heard of anyone actually having a problem there though. Youa re right though, Ford uses 1/2" studs instead of 9/16ths. I think I may well drill out my hubs and put in the 9/16s studs. Different lug nuts front and rear will be annoying.
  10. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Great, I learn new info every day. Thanks fellas :D
  11. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Well thanks for all the help, but as much as I hate to admit it.....it will be cheaper for me to simply buy a 3RD ORD Doubler, and sell this F*rd version to someone else.
    By the time I add up the acquisition cost of a F*rd HP60, parts swapping, replacing any bad parts I find, locating and rebuilding a F*rd version 205....I'm spending more than if I just bought a new Doubler and used my existing (and known good) D60 and NP205....
    Guess I'll start watching the "FOR SALE" area on a more regular basis. :deal:
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Just do what Watson did on Wally and get a ProRock (or whatever you want) center section, some tubes, and after market end forgings. You will get stronger parts, more ground clearance, high pinion, and be able to use all Chevy stuff in it.
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    except ring gear. Pro Rocks use the reverse rotation ring gear.
