Parts Washer Pictures
Discussion in 'The Garage' started by rdn2blazer, Mar 28, 2005.
  1. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    Pictures before powder coat. I started with a 60 in long by 20 in diamiter new fuel tank, .08 thick steel. The ends were domed in so i cut them off and fliped them over rewelded them on so they were domed out. than split it length wise and cut the ends of to the length i wanted it to be. The color will be bengle tiger orange. its i bright orange, should be done in a few days.
    __________________
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Nice work, what color are you going to powder coat it??
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    wow, now THAT is a parts washer! You could do a whole freaking axle with that thing. I'm guessing that was the idea. Sweet man.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Wow. Very nice!!!
  5. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    sleddog, yes thats why i built it, cause cleaning axles in the driveway with oven cleaner or any kind of cleaner sucks. its allwaya a mess, same with the wire wheel and scraping method. its alot of work with slow progress. you end up smearing the grease around. and load up your wire wheel with grease. sure it works allright, but when you hose off the cleaner end even blow off the excess water you still get flash rust, and i hate rust. thanks for the props.
  6. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
  7. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,025
    852
    Pinckney, MI
    Took me 6-7 hours with the scraping and wire wheel metheod. Nice work !!
  8. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    That is awesome. Nice work. :grin: :grin: :grin: :grin: :grin:
  9. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    Parts washer
    Heck,fill it with charcoal,,,throw some grates on it,,,40 - 50 steaks,,,we'll bring the beer!!!!!!!
    Nice job though !!!
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    Will you be running a pump of any kind for a flow thru brush? Just wondeirng what type of pump you would use.
  11. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Can use one of the "Little Giant" pumps from Grainger or McMaster. Just don't use SuperClean for the solvent. It kills the seals or something, after a month or so the pump is DOA.
  12. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    I will be running a flow through brush that has a on/off button built into the brush. I bought the biggest submersible pump for automotive parts washers using solvent base solvents that is 110 volt. I also am using a plastic tank rated for chemicals and acids, so solvent wont hurt it. will be using a filter in the drain back line to keep solvent kleen as posible. powder coat called and it done, I pick it up tomorrow at 6 am, will post pics as soon as i can. also of my tube bender, I had that coated the same orange.
  13. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    ntsqd, yes thats the pump I have.
  14. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Thats badass dude. I'm gonna keep yers in mind when I go to build one.
  15. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    wasted wages, the though had crossed my mind. :grin:
  16. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Very nice. Can't wait to see the final pics.
  17. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Post resurection! So do you have a link or source for the pump and nozle that you used? I'm looking into making my own as well and parts rundown would be appreciated. Thanks
  18. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    everything for this was purchesed through Mc Master Carr. dont have the info on the pump right off hand but I know I bought the biggest pump for solvent they sell for 110 volt. go to McMatserCarr.com, you should find what you need.
