passanger seat stress cracks
Discussion in 'The Body Shop' started by Icemanf4i, Jan 31, 2006.
  1. Icemanf4i
    Icemanf4i Registered Member
    Jan 8, 2006
    30
    reno, nevada
    My 88 k5 has stress cracks around the back 2 bolts on the passanger seat floor pan, do i have to cut it out or can i just weld the cracks and or reinforce the pan in that area??
  2. kotton
    kotton Registered Member
    Sep 1, 2004
    64
    Orange County, California
    I had cracks on both the driver and passanger side. I just welded the cracks up and havent had any problems since.
  3. 87GreyGhost
    87GreyGhost Registered Member
    Feb 15, 2006
    74
    Corpus,Texas
    Same problem here..with my 87 on back passenger..going to weld in the next week or so..
  4. Icemanf4i
    Jan 8, 2006
    30
    reno, nevada
    im just going to replace the floor pan on that side. I went by a welding shop and they told me even if i welded the cracks it would continue to split and i would be better off just getting a new pan and putting it in .
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    They gave you a load of crap, just weld it up. Maybe reinforce it from the under side. There is no reson to replace the floor pan just for a crack.
  6. Icemanf4i
    Jan 8, 2006
    30
    reno, nevada
    yea but the cracks are spidered and have gone through both back bolt holes plus i already ordered the pan so....
  7. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Stop-drilling can work on cracks if found early enough.
  8. blowedupmotor87
    blowedupmotor87 1/2 ton status Premium Member
    Mar 14, 2007
    2,492
    17
    Charlotte, NC
    I feel your pain on those cracks, I ripped out my whole interior and discovered that one of the rear mounts of my driver's seat is resting on the heat shield below the floor because of how cracked the floor is (the cracked area is almost a foot front to back!). Almost all the other front seat mounts are cracked too. I don't know how to weld so, once I get the truck running again, I am going to take it to a body shop, hopefully they won't gouge $$$ me too bad! At least, I now know I am not the only one that has had this problem, I was shocked when I found it.:eek1:
  9. Tabb
    Tabb ROLL TIDE! AGAIN! GMOTM Winner
    May 2, 2006
    3,566
    21
    Heart of Dixie
    I just recently discovered stress cracks around all four corners of both the drivers and passenger seats.:mad:
