Passenger Door Lock not unlocking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83ZZ502_Jimmy, Nov 1, 2002.
  1. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    87 K5. Pwr door locks /forums/images/graemlins/1zhelp.gif
    I have taken the door panel off. (very difficult with door closed....) Disconnected pwr acuator, (which works fine)
    I have even taken apart the drv side to get a look at the workings. It all seems the same. But the mechanism will not unlock the door. Key wont, nothing. I have pried and pushed and cannot get the bracket to move fully to unlock the door. /forums/images/graemlins/mad.gif
    Anyone have a problem like this, any insights from anyone? /forums/images/graemlins/confused.gif
    Thanks in advance,
    John
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Try pulling the inner door handle quick and hard and release it letting it snap back into position. Sometimes this method works to free up the lock.
    Mike
  3. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    No go... /forums/images/graemlins/frown.gif
    But thanks.
    John
  4. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    Try the same thing from the outside. Push it in hard and let it snap back. Hope this helps!
    Mike
  5. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    No again, but I really appreciate the response. /forums/images/graemlins/smile.gif
    John
  6. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    Well, looks like it is time for the "big hammer"! /forums/images/graemlins/grin.gif
    Mike
  7. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    do the method mentioned before many times. keep trying do it real quick but not hard enough to break your handle. every chevy truck eventually does this and thats an easy way to get it open to fix. Pull handle fully or press button fully in and let go as soon as you do then try to lift lock from inside (may have to have some one help you) If this does not work after many tries then you probably have bigger prob.
    Chris
  8. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Well Thanks guys, it finally worked. I cursed at it the right way and it finally gave way.
    I never thought that could happen, but the methods above worked great. /forums/images/graemlins/thumb.gif
    John
