passenger/ driver seat swap?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Aug 26, 2003.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    How easy is it to swap around these seats? DO the brackets come off how does it work?
  2. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Yes they will Just swap the seats not the mounts...
    Shouldn't take more then 15 mins a seat. There is only 4 bolts if i recall.
  3. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Yeha but dont you have to switch the brackets around becaus ethe drivers seat mounts with all four corners to the floor and the assenger seat tilts upwards and has a hook in the back.
  4. patrickcampbell
    patrickcampbell Registered Member
    Sep 11, 2002
    60
    switch just the seats! NOT THE BRACKETS! good luck
  5. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Patric is right. Just the seats. There are a few extra threaded holes under the "frame of the seat" They will thread right in. I did this about a year ago. Its nice you may notice that he padding is a little different on the outer edge. If you havn't changed them yet when you do you'll notice that the padding is a little thicker on the "door" side edge. I think GM did it because they want your body to stay more in the center of the seat. But you'll get used to it.
    I ended up tossing them all in all and installed "Pontiac Fiero seats" for $28 bucks and some raw steel and made a nice frame and tied all the seats to that.
    Good luck with the swap. Its easy like Sunday morning...
    KEN /forums/images/graemlins/cool.gif
