Passenger seat brackets
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Chris_T, Jan 27, 2003.
  1. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I posted on the Parts Wanted board, but I was wondering if any one here might know of a source for the passenger side seat brackets for a '72. I've only ever seen bench brackets and had no luck with the yards
  2. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    no one?
  3. Dave_S
    Dave_S Registered Member
    Apr 11, 2001
    56
    Portland, OR
    Are these the same as the 71?
  4. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    A far as I know they are. If not, will someone please correct me. My front brackets are OK, but could still use replacing. I need the rear bracket that bolts to the seat as well as the fixed that mounts to the floor.
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I think the design stayed the same till '75 or '76.
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    '69-'72 brackets are perfetcly interchangeable. The '73-'76 bracket is a little different, but I think it will bolt in (it is visibly different from what I have seen in the Blazers I've been in at the yards, so I cna't say that they will fit).
  7. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    That's what I meant Steve they seam to be the same style so they might work?
  8. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    I've tried a bracket from a yard, from a '76 I believe. It looked like it would work, but when I bolted the 'latch piece' (for lack of a better term) to the floor, it didn't line up and secure the seat from flipping forward. That may or may not have been an original latch in the '76, so I can't really say either
  9. k5_kid
    k5_kid Registered Member
    Aug 26, 2002
    12
    Boston
    Are you still looking for this? I believe I have a spare set.
  10. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i pulled a complete seat out of a post 75 blazer.not sure on the year but it lined up in the rear.the front i had to weld new foot plates to line up with the older style bolt pattern.i also put some aluminum blocks in the rear to lift it off the floor a little to match up with the raised spot on the front of the floor where it bolts in.not the easiest rought to go,but it works and only cost me 5 bucks at the junkyard
