Passenger seat?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pugsley, Oct 29, 2001.
  1. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Is there any adjustment in the passengers' seat, or do I just have to live with it rattling? I had a piece of heater hose around the pin, but it was still loose (only cut down on the noise) - anyone know?
    ......And knowing is half the battle
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  2. eastk5
    eastk5 Registered Member
    Jul 24, 2001
    50
    Norfolk Virginia
    i have an 84 when i bought it had ( and still does) two pieces of exterior molding clued to the bottom rear seat on either side of the pin.
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I have to re-apply foam weatherstrip to my rubber bumpers ever so often to keep rattles down.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    Yes, there is adjustment for the passenger's seat. If you look up where the big "hook" that clips down into the floor is connected to the seat frame, there should be some shims in there between the hook mechanism and the frame. Just loosed the bolts up and pull one or two out. Or if all of the shims are already out, you could glue some old pieces or carpet to the bottom of the seat on the two big parts that touch the floor.
    As the carpet and pad wear down, this gets looser. I had to add washers to mine after I put in new carpet , since now I have have two pads.
    <font color=green>There's nothing like the smell of a rich V-8 in the morning...</font color=green>
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Thanks a bunch - Once I got the shims out it was perfect. Now if I can just keep track of them for when I recarpet it, I'll be doing pretty good[​IMG]
