passenger side power window switch????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jackedjimmy350, Sep 10, 2002.
  1. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    ok i bought a new switch... the problem is that there are 3 wires coming from my door panel and the back of the switch has 5 prongs, nipples, ...whatever you call em. i dont remember which wires go on which prongs? anyone know?
  2. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    I got a set from advance auto and they were exactly like stock 6 prongs for drivers double switch and three prongs for passenger door .Maybe they sold you the wrong switch ...........
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Did you yank the wires out of the connector? You should have been able to just unplug the connector from the back of the old switch, then plug it onto the new switch.
  4. jackedjimmy350
    Oct 20, 2000
    3,141
    well i meda the mistake of taking the wires off one day and getting the new switch until a couple days later. anyone have a chiltons were they might be able to look at it?
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    But my point is that the wires are not supposed to come off of the switch one at a time. /forums/images/icons/shocked.gif The stock config is that the wires all go into a connector that attaches to the back of the switch. So if you just unplug the connector from the old swtich, it will only fit the correct way on the new switch. Is this a truck that was converted from manual windows to power windows? Sounds like this is the case and that the wiring harness got cut up. /forums/images/icons/frown.gif I don't have a power door apart right now to see when color wire goes to which pin on the switch. /forums/images/icons/frown.gif
  6. jackedjimmy350
    Oct 20, 2000
    3,141
    duh...i havent been thinkin straight today. i thought something was missing (the connector). forgive my stupidity today, and thanks for the info. /forums/images/icons/wink.gif
