Passenger side tail light wont work. Why?
Discussion in 'The Garage' started by afroman006, Mar 23, 2003.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    My passenger side tail light stopped working today. Nothing on it works. Blinker, brakelight or back up light. I replaced the bulb in the brake light but still nuthin. I checked the fuse box and no fuses are blown. What is it? Is there anything I should check that I havent? Thx
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    well, since i have to rewire my taillights monday, I'll give you all the reasons why mine DON'T work and you can go from there. First, my truck is an 87 blazer. I live in the salt crazy northeast. My truck has 2 different trailer harness's wired in and neither work. connections were spliced in and never sealed from elements. connecter from main harness to taillight harness has broken/corroded terminals. wire harness pinched when some idiot put trailer hitch on. and ground wire on passenger side broke off the terminal to body.
    I am redoing the whole taillight harness.I have no reverse lights and no running/turn lights on passenger side.
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I recently had some hassles with my taillights/blinkers, etc. I strongly suggest that you make sure you have good grounds. I did and my problem was solved.
  4. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    lay under the truck and look up under the DRIVERS side and look for a connector, it is a harness that splits off from the drivers tail light to the passengers side, if it gets disconnected none of those lights will work, and if you have one of those plug in trailer harness things, its probably that. mine just did almost the same thing and it was the trailer plug. i lost brake lights and blinkers on that side, unplugged that trailer thing and it worked fine
  5. Phreak480
    Phreak480 Registered Member
    Dec 13, 2002
    36
    dix hills, ny
    also check the wiring up on the side of the column i had a loose wire and it caused my right tailiight not work at all
  6. afroman006
    Aug 21, 2002
    2,876
    Cool thx guys I'll try all that. My burb has an aftermarket trailer light receiver, the big fat one with the center hole and 4 or 5 tabs around it. That's probably it. Thx
  7. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    If its newer body style like 88-up id bet its the whole light bar.. its got 3 places for the 3 bulbs.. Ive had to replace mine a few times its like 20 bucks but i found out discount doesnt carry it anymore.. /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif www.zombieoffroading.8m.net
  8. afroman006
    Aug 21, 2002
    2,876
    Nah the burb's the old body style. I got under and looked at it and thers a plug connection on top of the gas tank that I guess ratled loose. I stuck it back together and wrapped it in duck tape so it wont come apart again and they work now. Thx for the help
