Passenger side tie rod end won't budge!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Nov 17, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Passenger side tie rod end won\'t budge!
    The drivers side bolt popped off with a couple wacks, is the passengers side any different? Is it somehow threaded on there?
  2. 74Chev
    74Chev 1/2 ton status
    Sep 19, 2002
    102
    Oregon
    Re: Passenger side tie rod end won\'t budge!
    It's not threaded in. You can use a pickle fork to remove it but it will probably ruin the grease boot. But it will get it serarated. Try smacking the side of the eye on the steering knuckle with a small sledge. This will casue the eye to momentarily distort freeing the tie rod. Another thing to try is have a buddy hold the head of a sledge sideways on the eye and whack the side of that sledge with a heavier sledge. Good luck.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I'm kinda confused? Are you talking about the castle nut? Those are the same - just apply massive amounts of torque with a long breaker bar. Then they should unscrew.
    Or, are you talking about the "bolt" itself - the part of the tie-rod that goes through the knuckle. If so, no...it's not threaded. It's what's called a taper fit. That's what gives everybody problems with the steering arms. If you have a pickle-fork/tie-rod separator, try that. Otherwise, take a 3lb hammer and hit right on the knuckle. It's kind of hard to describe, but just hit the knucke square-on, right where the tie-rod goes in. This - after repeating many times - will bust up the rust-death-grip, and the end will fall out for you. Worked for me. Combination of hiting down on tie-rod then on knuckle then on tie-rod, etc. is good too.
  4. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Okay thanks. I've got no use for this tie-rod I'm just trying to get it off so I can install the Rock Rod. Castle nuts weren't a problem, just the bolt holding the pass side on. I'll keep on bangin it though. Thanks
  5. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Glad to hear you recieved ok /forums/images/graemlins/grin.gif Good luck with getting out the old one, they can be a pain in the a$$ sometimes.
  6. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I got a pickle fork if you need it still. Give me a hollar, I'll be working on my truck Today.
    John
