passing emissions in Houston
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by trogdor4x4, Mar 6, 2004.
  1. trogdor4x4
    trogdor4x4 Registered Member
    Dec 15, 2003
    37
    Spring, TX
    /forums/images/graemlins/confused.gifI failed (HC) emissions testing today, what can I do to pass?
    91 Stock 350, stock exhaust; replaced plugs, wires, cap, rotor bug, and changed oil last week.
    Test results:
    High Speed- Standard 126 current 180
    Low Speed- Standard 129 current 162
    What can I do to lower it?
    oh yeah, gas tank was almost empty (I don't know if that matters). Had to go straight to gas station.
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    I figure if I can dodge the law for 2 more years, I am home free in CA with my 77... /forums/images/graemlins/whistling.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    High hydrocarbons is a sign of running rich or having a misfiring cylinder. An O2 sensor that is on the edge of failure could be the culprit. It also helps to take the rig out on a quick highway run and make sure that the engine is warmed up enough to be in closed loop mode and the cat is good and hot just before the test.
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    AC Delco O2 sensor....make sure you have a 195* thermostat...it cost me $75 diagnosis, $45 for an Autozone Bosch O2 sensor (fawked right outta the box), $40 for an AC DElco sensor that works...changed the EGR (on the advice of the testing station I'll Never go back to), and took the advise from this site to check for a 195* thermostat (had a 160) which was keeping it out of closed loop ($6 or so)...if I had asked here first, I woulda saved $135 or so.....BUT since I had it inspected, changed the EGR, took it back and failed...I had to take it to a Certified Inspection station where I got the straight skinny....I also had to pay for another inspection....Mines an 89 stock TBI with ceramic headers and duals (130K miles)...good luck... /forums/images/graemlins/thumb.gif
  5. trogdor4x4
    Dec 15, 2003
    37
    Spring, TX
    I changed the O2 sensor but can't get it tested until friday. It seems to idle smoother (I asume that made the difference) I also found that it was advanced to 2 degrees disconnected. I put it back to zero. I posted about plugs, I don't know if that will make any difference with the HC output. They are r43 delcos.
  6. trogdor4x4
    Dec 15, 2003
    37
    Spring, TX
    failed again, but a little closer
    I am going to go with the r45ts instead of the r43ts that I put in last week (that is what was called for as a stock replacement). Praying Hard.
  7. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Try this RxP ! I used this product both times in California to pass emissions test that I barely failed! Works great!
    Bill
  8. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Do an oil change(it works), fill up at a speedway (or gasihol station with 10% ether) and put a bottle of dry gas in. Make sure the truck is warmed up before hand when they do the test. Working EGR will bring your NOx readings down. Replace your O2, should be a 1 wire for its cheap.
  9. K5Jimmy
    Sep 21, 2000
    1,141
    So....How did ya make out with yer inspection? /forums/images/graemlins/thinking.gif
  10. trogdor4x4
    Dec 15, 2003
    37
    Spring, TX
    After trying small things and not passing, it ended up being my catylitic (?) converter needed to be replaced. went from about 170 to 44. wow. Thanks for all of the ideas.
