Patch Panel ??
Discussion in 'The Garage' started by Justin Fleming, Sep 19, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    765
    4
    Oxford MI
    Anyone know where to get a patch panel for the floor pan in the back of a k5 near the tail gate?? This would be different then just a flat piece of metal to weld into place. As the floor pan back there is not a flat contour.
    thanks
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
  3. djhn9
    djhn9 Registered Member
    Jan 2, 2005
    7
    Evansville, IN
  4. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    No..... I need the actual floor(witch would be equivlant to the bottom of the bed in a pick up truck)......not the tail end piller...... If I could attach a pic I would but I cant....
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    You need the section of rear floor where the ribs taper down and then go into a flat panel which is then attached to the tailpan which is posted above. Correct?
    If LMC doesn't have it JC whitney may.
  6. bcrewcaptain
    bcrewcaptain Registered Member
    May 15, 2004
    60
    Charlottesville, Virginia
  7. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
  9. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    the only bad part is I only need about 6 inches for both sides.....
    thanks for the find......
    I may just cut out the bad spots and have some one with a brake bend what I need.....Probably a lot cheaper.....
    thanks
    again
  10. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    cut up an old bed!
    I've used peices of a pickup bed from a junkyard for patches before--same "ribs"in it!..beats paying good money for a tiwan panel,and throwing most of it away!. :doah: :crazy:
  11. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
  12. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    I think that is what I need , but there is not pic.....have you got one of these in the past? Is there a pic? Basicly it is 16" tall by the width of the bed?? Does it have the ribs in it?? can you scan the pic?
    thanks
    again
  13. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    never mind......I downloaded the catalog and basicly that looks like it would work great for what I want to do and the price is right.
    Ps. Awsome catalog for all the little tiny things that you dont knwo what to call them or where to get them
    Justin
