Patching a BIG hole in a tire
Discussion in 'The Garage' started by Shaggy, Jul 3, 2002.
  1. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, so I'm pretty sure I already know the answer to this, but I have to ask anyways. I have a 38" radial Swamper that has a big slash in the sidewall from some crap in a mudhole in Hollister. the cut is about 5" long. I don't think that it's possible, but I want to find out if there is ANY way that I could get this to hold enough air to act as a trail spare. I know that it will never be safe to use on the street again, but the thing is practically new and if I could figure out a way to make it a servicable trail spare then that would be cool. I was thinking that I could maybe stitch the hole up with something then boot the inside with a big honkin patch. Any ideas, or should I just forget it and toss the thing in the dumster? Here is a pic of the hole in the tire. </font color>
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Damn that's a bigass hole!
    I guess you could sew up the wound and then find a big inner tube to put inside.....
  3. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I saw something once about trail fixes and it said that in a pinch you could sew a tire shut and put alot of duct tape all over it to hold air so i guess if you patched as best you could i bet you could use it as a trail spare. Ive never tried it though.
  4. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    I heard about shoegooing a shoe sole inside the tire. I've personally as an emergency fix, cut a quad tire and siliconed it as a patch for my regular tire, it got me off the trail and to where we could get a trailer
  5. ratpack7
    ratpack7 Guest
    Back in the old days my grandfather used to put a tube in a blown tubless tire to use it as a spare.
    I dont know if you can even find tubes any more but it might be an idea. patch it from the insde the best you can
    and see if you can come up with a tube that will fit. There might be a farm equipment application that uses that size of tube.
    Just an Idea.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've seen pics of a Swamper that had a sidewall hole repaired using a heat vulcanizing patching process. They actually melt the rubber back together. It leaves an ugly scar on the sidewall, but it works. Check with a place that repairs farm tractor tires. They sometimes have the machine to do this. /forums/images/icons/cool.gif
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Cool, thanks Harry. Now all I need to do is find a place that repairs tractor tires. Probably won't be easy in the Silicon Valley /forums/images/icons/wink.gif ... </font color>
  8. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    if you can find a farm imploment tire dealer they should be able to put a big honking patch in it. they do it all the time around here. but like you said i would only use it for a spare.
    good luck.
    dave
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Head down towards Gilroy. I'll bet there's a place down there that knows about tractor tires. /forums/images/icons/cool.gif
  10. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Actually got to thinking that there should be tons of places out in the central valley, my brother lives out there anyways so next time I go out I'll throw the tire in the back of my wife's Subaru and see if I can find a place to fix it. Thanks again guys! </font color>
  11. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well shaggs, you can come on over to my house and theres about 200 shops around here /forums/images/icons/grin.gif. Bakersfield is an farming town.
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Hey Willis, yeah, I'll just pop over tomorrow afternoon and we'll take care of that /forums/images/icons/wink.gif. It's only like what, 300 miles or so? /forums/images/icons/smirk.gif </font color>
  13. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well, thought I would offer /forums/images/icons/smile.gif. Anyway, the place I was at today that was fixing my trailer brakes was repairing some semi-truck tires. They used a rubber pad on the backside that was heated with an iron which glued itself to the tire. Then on the outside they used melted rubber to fill the gap and then smoothed it. And that truck was going right back out on the road so I'm sure it would work for a spare.
    Alot like this:
    http://www.patchrubber.com/tire_repair/12117-pass.html
  14. Mike.S
    Mike.S Registered Member
    Jul 4, 2002
    30
    S.E.TN.
    Willyswanter and Shaggy, did you guys get kicked out of off-road or just get borred there ? I've just recently started going back to off-road but under the name Teri for my wifes sake. Its good to see yall. Later. /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif
  15. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Ohhhh so thats who Teri is:). Personally, I like the SFA board there but I'm getting pretty sick of the IFS board there. 1/2 the people drive me nuts.
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    DANG!! Now that's a gash!! /forums/images/icons/shocked.gif I have never even seen tires with gashes this big, fixed. /forums/images/icons/tongue.gif
    How about the warranty on the tire? Did you get it and does the tire still look new?
  17. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Mike - There's just more people here and the knowledge is more technical. I ask stuff here that I wouldn't ask at ORC and learn stuff from lurking that I've never come across over there in 3+ years. It's hard to start from the beginning over here though, and it appears that I have somehow managed to acheive permanent "Pavement Pounder" status. Not that it matters I guess. /forums/images/icons/tongue.gif
    I still go to ORC, we got them to make an SFA board a while ago but it's pretty slow, like 1 post there for every 20 here. Most of the die hards go to the SFA board but now there are alot of guys on the IFS board that mainly just want their truck to look pretty, although some of them still use their trucks off road. Good to see you're still around.
    Wes - the tire is probably about 4 years old, still has 85-90% tread on it though. I got it at 4WPW and they wouldn't cover it because the cut was not in the tread area. /forums/images/icons/mad.gif </font color>
  18. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    I think that there was somwone else on the board who had like 2000 posts and was still a pavement pounder.
  19. Mike.S
    Jul 4, 2002
    30
    S.E.TN.
    Shaggy, how about those brake lines? Is it a complete set up or what ? Would my brake lines fit into the 44 and 14 or do they have differant fittings ? I'm shottin in the dark when it comes to brake line so I'm not sure what to ask. My truck still has factory lines on now and I have a 2" lift, no problems thou so I guess the question is, do the lines you have fit to a 44 and 14b ? Are they extra long to compinsate for lift and articulation ? And the last question, Would my factory lines work ? Help me out here, I feel stupid and I'm sure I look stupid too !!! /forums/images/icons/grin.gif /forums/images/icons/crazy.gif /forums/images/icons/confused.gif /forums/images/icons/blush.gif
  20. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    That sucks. /forums/images/icons/mad.gif If you buy the road hazard warranty at Discount Tire, they'll replace it no matter how it got damaged. I took in a BFG All Terrain that had about 3,000 miles on it, with just a chunk torn out of the sidewall. It still held air, but I stopped in to ask them if it was safe to drive on. They replaced it with a new tire. /forums/images/icons/cool.gif I took in another tire with a gash through the sidewall from a nasty rock on old Tincup Pass in Colorado. They replaced it with a new tire. /forums/images/icons/cool.gif
    Hmmm, I was kinda looking at 4WPW's Pro-Comp tires, but if that's how they deal with customers, I'll just go see what Discount Tire can get for me! /forums/images/icons/shocked.gif
