Pattern for Custom Rear Bumper Mount Brackets - Who Needs One??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Apr 23, 2002.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    I just completed the Custom Bumper Brackets for my rear bumper. Does anyone need a copy of the pattern? I can create a few out of 1/8" steel. I used the same pattern and then layed it on top of the 1/2" steel I am making the brackets out of. The pattern is TIGHT and nearly perfect. The bolts match up excellently. I have made the bracket to fit the three bolts that are part of the factory mount and the two bolts that are part of the bracket that is angled off the frame. I will post pics tomorrow. I should have the bumper all finished tomorrow. I have the brackets on the K5 now and will use a floor jack to position the bumper in place. Once I have it level and in the correct position, I will tack it to the brackets. Then I'll take it off and cart it to the welding booth so I can use the arc welder to get it together with the best welding rods I could find. I am using 6011 rods to get good initial penetration on both sides of the brackets then I an going to use 7018 rods for extra fill and strength. I have gotten quite good with the arc and mig welders so I hope all goes well. I have yet to figure out how to latch the tire carrier to the damn thing but that is going to be the last step. I have two early designs but I do not know if they will work. So... let me know about the templates.
    <a target="_blank" href=http://www.geocities.com/keywestk5/Bumper.html>http://www.geocities.com/keywestk5/Bumper.html</a>
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Keep in mind the spare may cover the tail light. That bumper looks killer.
  3. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I might be interested. In your design, did you keep the tailgate spring incorporated with your brackets (The curved hook thing that wraps around one of the bolts)?
    Ross
  4. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Sweet! Looks alot like the bumpers that Ranch Hand makes, only they don't make for our truck (despite begging and pleading). You thinking about making a few of them?? I know I'd be interested in one.....
