PAUL NEEDS HELP!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, May 5, 2002.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Hi guys! This is Paul's wife Kim. He in the middle of a truck repair and needs help. He's putting on a new steering stabilizer and he can't get the sleeved rod out of the tie rod end on the old one. PLEASE HELP, He's waiting for a call from me. Thanks in advance!
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Heat it if possible and whack it hard!!!!!
  3. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Soak it good with PB Blaster and put the nut back on and use a BFH.. My took some time to get out, but I prevailed.
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Carefully smack the tie-rod with a hammer, right where the taperd end goes into the tie-rod, a blow 90 degrees to the bolt. With a hard enough impact, it should un-seat and sleaved bolt should be easily removed.
    Try holding the tie-rod or support it some-how, to help keep the strain off of the tie-rod.
  5. Can Can
    15,552
    136
    Thanks for you help guys. That's what he thought, but thought there might be another trick. He said he will fill you in later.
  6. Can Can
    15,552
    136
    Thanks, brothers/forums/images/icons/smile.gif!!!! I can't believe how hard that sucker was wedged into the tie-rod end/forums/images/icons/tongue.gif........I ended up using a tiger torch to heat the tie rod end up and after a couple of solid whacks the bolt popped out, easy as pie.
    I called Kim and walked her through the posting process and, as expected, the brotherhood came through!!! Thanks again, guys. Nothing like having a remote connection to CK5 when you need it, eh?/forums/images/icons/wink.gif
  7. Grim-Reaper
    7,385
    Atlanta
    The adjuster sleeve is only $7 or so bucks (US).
