PAUL UPDATE!!!!!!!!!!!!!!!!
Discussion in 'Mid-Atlantic Region' started by wraenking, Jul 11, 2004.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    paul, i got her started today!! i didnt screw with the timing yet cause i didnt have time, but there is a unusual amount of gas coming out of the tube on top of the carb. is this screwed up? is it time for a edelbrock? lol
    anyone else also, i would appreciate any input.
    thanks
    tom
  2. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    Re: PAUL (ryoken)
    hey i think if you are really good with a scriber and have a steady hand you can get it back into place with out removing the carb /forums/images/graemlins/thumb.gif
  3. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    Re: PAUL (ryoken)
    yeah, just unscrew the flatblade screw, take that little bracket off, rehook the bottom, then put the bracket back on. luckily its an older Q, the newer ones have a fixed upper bracket... flashlight will be handy to see down that chokerod hole.. if ya need a hand give me a yell, i could prolly stop by tuesday after work...
  4. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    Re: PAUL (ryoken)
    sounds good paul. i shuold be able to do it. would that prevent the truck from starting?
    hopefully my battery will be charged when i get home and ill find out.
  5. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    Re: PAUL (ryoken)
    yeah, that'll screw ya up.. choke wont open or close properly.. it'll start but the choke will more than likely stay closed.... you could manually operate the blade when ya fire it up.. but it should be an easy fix... any probs, give me a buzz tonight, i'm "usually" home by 6... 732 237 9354
  6. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    Re: PAUL (ryoken)
    check the top....edited
  7. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    Re: PAUL (ryoken)
    might be a float level problem cuasing the fuel to come out of the vent....If your gonna upgrade Go with a
    SPEED DEMON.. /forums/images/graemlins/thumb.gif
