PC guys: Memory
Discussion in 'The Lounge' started by 84gmcjimmy, Oct 12, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    What do all these mean? They are Memory for computers, listed on ebay.
    * DDR
    * EDO
    * FPM
    * RAM
    * RDRAM
    * SDRAM
    And which is better?
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    The only one I know for certain is RAM = Random Access Memory.
    All the other types you listed are variants on the same basic theme.
  3. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,021
    849
    Pinckney, MI
    DDR - Double Data Rate(PC2100,2700,3200 etc)
    EDO-Extended Data Out( found in 30 or 72 pin simms(single inline memory modules)) -old
    RDRAM- Is also known as rambus or rimm(on intel boards only mostly proprietary)- crap and expensive
    SDRAM - also known as SDR single data rate Older(PC66,100,133)
    RAM- Random Acess memory
    thats all I can remember right now
    Edit: It depends on what system your running. For AMD 64's and the like DDR is better, because of the hypertransport feature
    For Intel boards they are using DDR2 which is supposed to be faster then DDR but the performance gains over DDR is very small due to the architecture of the chip
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Alright thanks I sort of get it now. Now I need more research.
  5. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Also you left off DDR2. New verison of the Double Data Rate, so for used only by Intel.
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If youre buying a new computer, get DDR or DDR2 and more is better.
  7. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    I think FPM may mean Floating Point Memory, but I'm probably wrong. It's been a long time since I tore into a computer's guts, so I probably need to take a new class on all it.
  8. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    DDR3 is the newest
