pcorssmit:
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by laketex, Feb 7, 2001.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Where's the specs on that rig of yours? That's my style too, lift a couple inches and take the rest out of the body. What kind of beadlocks are you running? ECT ECT. We want DETAILS man [​IMG]
    Durant, Ok
    I love my SAWZALL!!!
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    '83 Blazer
    Front Axle: Dana 60, rebuilt, 4.56s, Detroit.
    Rear Axle: 3/4 ton 14 bolt, 4.56s, Detroit, custom disks.
    Steering: Crossover using 2wd box, Avalanche Engineering steering arm, Scout pitman arm, heim joints and 1-1/4" OD, .287" wall DOM tubing, 3 stabilizers, frame reinforcement plate and ORD brace. Heim joint/tubing tie rod, reinforced w/ angle iron.
    Front Suspension: 4" Pro Comp front springs, Homemade shackles (1/2" longer that stock), single Pro Comp shocks, ~3” lift.
    Rear Suspension: Stock springs w/factory overloads, shackle flip using OE stock hangers, single Pro Comp shocks, ~3” lift.
    Brakes: Hydroboost, 1 ton master cylinder, braided steel extended lines, adjustable proportioning valve.
    Tires:
    Street: 35x12.50R15 BFG Muds, bald, on 15x10 chrome mods w/4-1/8" backspacing.
    Trail: 15x39.5-15 TSL Swampers on 15x10 American Racing wagon wheels w/4-1/8" backspacing. I think the bead locks are MRT, they were put on by Tru-Design wheel.
    Motor: Originally 6.2 Diesel, replaced w/'87 TBI 350, MSD 6AL, full length headers, single big block Flowmaster.
    Trans: Stock 700R4, rebuilt, slips bad in 2nd.
    T-case: Stock 208.
    Driveshafts: Stock, conversion joint in rear.
    Winch: Warn 8274 in old Warn winch mount/brush guard.
    Dual batteries, isolated, one starting & one deep cycle.
    Top:
    Summer: Kayline, older snap-style.
    Winter: Hard Top.
    Body: Lots of Sawzalling, grinding, cracks, and dents, w/a 5’ wide red bow tie on the hood.
    Sorry, I don’t currently have any (electronic) pictures other than the one posted under “Need pics of body trimming” (?).
    Pete
    '83 K5, 350 TBI (ex 6.2), Dana 60/14 bolt, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    Hey Pete,
    How much grinding did you have to do to fit the rims over the calipers? Sounds like an impressive rig.
    <font color=green>Joe Angelicchio
    86 Jimmy 4+3, 35-&gt;39.5 tires,4spd
    </font color=green>
  4. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    The rear didn't take much grinding at all, the front took lots. However there was still more metal left than the 1/2 or 3/4 tons start out with. If I didn't feel it was safe then I wouldn't have done it. Grind a little, trial fit, grind some more. I've seen a few other rigs with the same setup, and I know one of my buddies just put the same size wheel (different brand) on the 60 front under his '93 Chevy. They clear stock rear drums (Chevy) fine, and 3/4 ton brakes require some grinding. I prefer the 4-1/8 backspaceing since it's easier to steer, easier on the truck, and doesn't create as many fender problems.
    Pete
