pcv port on the TB **all cleaned up**
Discussion in 'The Garage' started by NEK5, Dec 7, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    in the process of cleaning out the clogged pcv port on my TB, but without having it pulled, its hard to tell what direction the port goes...It seems like it just goes in, then stops, so I`m assuming it either goes down, or splits to the sides...anyone have a clue???guess i`m going to have to put the frigging thing anyways:mad: :mad:
  2. goldwing2000
    goldwing2000 Guest
    It should go in and down to draw vacuum from the intake manifold.
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    so I`m gonna have to pull it to clean it out, eh?
  4. goldwing2000
    goldwing2000 Guest
    Unless you want all that gunk to end up in your cylinders.
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    It goes in and to both side IIRC. I highly doubt it is plugged in the TB anyway. Have you pulled the hose and ran the engine to check for vacuum there?
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Well, i got the TB off now, and all i got was a little gunk out of the port, and i`m not even sure what i`m supposed to be "cleaning" underneath it..If its not clogged in the TB, then where would it be clogged?
    Not sure i understand what you mean..
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ttt, need this done so i can drive it to work today at 4:30 PM :eek1:
    Should i just put the TB back on, or is there something I have to clean out?
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Which way should the vaccum be pulled from?
  9. dyeager535
    26,975
    Try blowing through the port on the TB and seeing where air comes from on the underside.
  10. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Well, as you, ryoken, and greg have told me to do that, I went out and did it. My face went red:eek1: . That baby as clogged. Little did i know, when i said it went straight it and stopped, it did stop, but only because of the brick of carbon in there. :eek1: :eek1: Guess who decides to show up, while on his companys time... my friends dad stopped by while I was out there, and gave me a quick hand..turns out it was clogged in the TB, and pretty bad too. Whoever said it goes in and splits to the sides was correct by the way...after taking a guess to where the port went, we stuck the pick in there, and gave a good couple whacks with a small hammer, and sure enough, the pick started moving slowly...sprayed the carb cleaner in there, look like the TB took a little $hit.:eek1: :eek1:
    He`s even gonna stop back in a few to see how I`m making out with it, and make sure i get the fuel lines back in right:D (long story)
    As soon as i get it back on, I`ll report back
    FYI: Yea, I have a laptop out in my driveway:pimp1: :pimp1:
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ok, all set now, she`s a suckin!
  12. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    That would be i who said that. :thumb:
  13. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Thats what she said
    :haha: :haha: :haha: :haha: :haha:
