pcv ?
Discussion in 'The Garage' started by bigbadchev84, Dec 14, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    Can i T my pcv valve to the back vacuum port on my edelbrock and plug the front port to make my engine look cleaner?
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    as long as its got full vacuum, its perfectly fine.
  3. diesel4me
    Jul 24, 2003
    17,581
    945
    Massachussetts
    yes any manifold vacuum source,but...
    If you tap into the vacuum hose that goes to the power brake booster,I'd get one of those little charcoal canisters that go in the hose,that GM used factory on 80's vehicles..it absorbs the fumes from the PCV system,and prevents them from rotting the rubber diaphram in the booster,which shortens its life quite a bit...
    I prefer to use one of the larger ports in the intake for the PCV valve--it needs a 3/8" hole to get adequate vacuum to work properly and to prevent oil deposits from clogging it rapidly...if it clogs,the PCV wont ventilate the crankcase,and oil will blow out of the seals,dipstick tube,past the rings,etc..:crazy:
