people w/ shackle flips install??
Discussion in 'The Garage' started by Bhintz, Jul 18, 2004.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    trying to install echobit flip and cant for the life of me get the bolt out that holds the shackle to the hanger, how did you guys do it compress the spring, let it sag all the way, unbolt the spring then do the shackle??????????? /forums/images/graemlins/1zhelp.gif
  2. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    When mine went on , we removed the axle and set the axle on the ground , with no weight on the springs and them just hanging the bolts came off easy ( AZ truck so that helps ) . For good measure we replaced the bushings front and rear on the back springs . /forums/images/graemlins/k5.gif
  4. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    We used a small come-along, a big hammer, a big screwdriver, jack stands, floor jack, ect.
    If you can find a punch that is about as big around as your bolt, you can hammer the punch through. That works for installing also, just put in the punch and then tap it out with the bolt.
    Another bolt may work instead. /forums/images/graemlins/whistling.gif
  5. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I have sworn at many of those frickin bolts /forums/images/graemlins/whistling.gif
    I used a trick on two trucks..
    hold a hammer on the head of the bolt
    have some one drive a same size bolt onto the threads of the stuborn bolt.
    once and "if" you can get 1/2 inch or more of the bolt head to stick out, take a wrench and applya side load on the shaft of the bolt, then use a rachet on the bolt head.
    the side load helps break the bolt free and quits the turning of it with the bushing..if this doesnt work go get a acedilen..sp torch or a small torch and heat it up, then op her out. Most rv repair shops and suspension places sell the factory shackle for 15 to 30 bucks already loaded with new bushings. Likly you may destoy the bushing getting it out anyway.
    If you need the # to the company I go through just let me know /forums/images/graemlins/thumb.gif
    good luck /forums/images/graemlins/hack.gif
  6. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    [/ QUOTE ]the problem is the gas tank is right there and I cant get enough on the the swing to move the bolt
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You might have to cut the head off of the bolt and hammer it that way.
    I had some front bolts like that once. I ended up taking a sawsall and cutting between the hanger and the spring to get everything out.
  8. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    just found a little torch do I just heat the head up then punch it out w/ a hammer /forums/images/graemlins/confused.gif
