People with 2-3" lifts - steering arm?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Apr 21, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    People with 2-3\" lifts - steering arm?
    I need to put a steering arm on my truck, I have a 3" lift, and can't find an arm for a truck with a lift under 4" Where did ya'll get yours?
    90K5
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: People with 2-3\" lifts - steering arm?
    Nobody makes any arms lower than the 4 inch raised ones. The only other option to do is to use the 2 inch drop pitman arm, like from Skyjacker.
    Another option would be to get the blocks to raise the steering arm. Superlift sells those. They come in 2 and 3 inch blocks. The kit includes new longer studs and nuts.
  3. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    I honestly dont think you need one.. i have had a 2.5' lift and a 3" lift and did not use or need one.
    Doesnt someone make a spacer for the steering arm ? or am i thinking of something else ?
    '89 K5..... 4" Tuff Country EZ Ride. 33's and a "Colorado K5.com" sticker. This site rocks!!
    <A target="_blank" HREF=http://www.tori89k5.coloradok5.com>http://www.tori89k5.coloradok5.com</A>
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    I would definitely use a 2 inch pitman arm, considering how the frame cracks around the gear box, especially on ANY amount of lift. This pitman arm will at least put the drag link back to the correct operating angle that it was supposed to have.
    Those spacers are just what I was describing above. They simply sit under the stock steering arm and are held in lieu of new, longer studs.
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have a 2.5 inch lift,and have not changed the steering arm. I asked about this topic about a week ago,and was told that if I did change it I would have better steering response. Don't know if I want to fork out a $80 bucks for a new one.
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    I would install the pitman arm and be done with it.
    The pitman arm is ALOT easier to change than those 2 or 3 inch blocks under the steering arm!!! [​IMG]
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Maybe I'll put a pitman arm on it when the steering box craps out....leaks a whole lot of fluid right now.....
    90K5
  8. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I have something like a 1 3/4" lift because I have 3 leaf springs up front, just shy of 3/4 ton. Think I would have to do anything? It steered like poop before the change and exactly the same after. Hopefully getting my D44 in, aligned, new stabilizer, and an ORD brace should help. (drag link was way off when i bought it)
