People with 86 Blazers...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChevyCaGal, Jul 11, 2001.
  1. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Does your rear window... if you are outside in back of the Blazer standing there... if you put your key in the lock, will it roll down? Mine won't... I can only get it to roll up if it's down with the key. I hate this. Is this normal or is mine acting weird? Thanks [​IMG]
    Stephanie <><
    <A target="_blank" HREF=http://www.chevycagal.homestead.com/steph.html>http://www.chevycagal.homestead.com/steph.html</A>
    I removed my quote so gay, vegetarian, minority, eco-nazis who love Jesus, nuke spotted owls, vote Gore and smoke medical marijuana won't be offend.
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Yours is acting weird. Mine has done that a few times. You have to basically take the switch apart and clean the contacts. The only way to get to the switch is by taking the cover off the inside of the tailgate and removing the 2 nuts that hold the swith in. then take the switch apart clean contacts, and put it back together. While your in there lube up all the rollers too. Good luck
    <font color=blue>Esteban</font color=blue>
    <font color=red>SEMPER FI TO MY BLAZER
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I've been needing to do this for a long time, mine doesn't work at all using the key. Hopefully just cleaning it up will work....
    Murphy's Laws on Life:
    "A bird in the hand is worth three Kleenex."
  4. Hathaway
    Hathaway 1/2 ton status
    Jan 2, 2001
    295
    Missoula Montana
    I'm with blazer guy, mine won't work at all with the key and i'm too lazy to get to it(yeah, right, lazy...4jobs...lazy... [​IMG])
    Dan, '86 K5, 5.0L v8, NP208, TH700R4, open 10bolts front and rear, 3.43gearing, K&N filter, 31x10.50R15 Trailhandlers
  5. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    I have an 85 for a good 4 years and my back window has never rolled down by the key. I just got used to it. I got bigger things to fix and modify.
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    My 85 and my Granddad's 84 are both screwed up - Mine won't roll up with the key, his won't roll down. The switch is a sufficient enough pain to get to, we just leave them that way and use the dash switch.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A> Updated finally[​IMG]
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Hey DodgeCaGal Mine is a 86 also and the window does roll down with the key..........Dan
  8. Ross
    Ross Registered Member
    Apr 19, 2001
    75
    IL
    i cant get the key in the hole
    1986 white K5
  9. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    I got what your looking for... Check out the pictures with the descriptive text on my web-page. It's a 1-2 hour jobb.
    <font color=red><A target="_blank" HREF=http://www.espen88k5.alloffroad.com>http://www.espen88k5.alloffroad.com</A></font color=red>
  10. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    My 90 Jimmy came with 4 keys; Ignition, doorlocks, rearglass, and console. What a pain.
  11. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    I've got an 86 and the key never worked the last 9 yrs. Plan on rebuilding the tailgate to new.
    <font color=green>Joe Angelicchio
    <A target="_blank" HREF=http://community.webshots.com/user/jangelicchio>http://community.webshots.com/user/jangelicchio</A>
    Lisle, Ontario, CANADA</font color=green>
  12. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    DAMN! YOU GUYS ALL HAVE KEYS TO ROLL YOUR WINDOWS DOWN???? MUST BE NICE.... [​IMG]
    <font color=red> Check out my truck @ </font color=red>
    <A target="_blank" HREF=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</A> [​IMG]
  13. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Espen, do you have to remove the regulator to access the nuts that hold the switch in?
  14. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Mine has never worked with the key.It takes 2 people to get it down.One pushin the button and one out back beating on it and pulling it down.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  15. Espen88k5
    Feb 19, 2000
    981
    Norway
    Yes the regulator has to go first, it goes out in one piece. It's nothing to worry about though. 3-4 bolts that screw into the tailgatewalls and it's out. First you slide the window upp all the way and rest it on something so it doesn't hang there by it'self. then go at the regulator... Fast and easy. The new keyswitch from Gm came with a new key, so I just switched over the insides of the new one to the old one, and kept the original lockcyllinder.
    Take a look at the pictures, and give it a go. It's all "easy tractor-technology"
  16. gpd4
    gpd4 Registered Member
    Jun 25, 2001
    55
    St. Louis, MO
    I have to climb back there with a cordless drill to make mine move...
    '85 Blazer... 9" lift... 35-12.50 BFG AT's...LOTS of rust
  17. MudBnny
    MudBnny Registered Member
    Jun 5, 2001
    10
    San Luis Obispo, California
    My rear window rolls up and down with the key, it's slow, but it works.
  18. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Thanks for the info, I guess I'll give it a try. I have to take the tint off the window and redo it anyway.
