People with HYDRO ASSIST come on in.
Discussion in 'The Garage' started by 81jimmyslt, Sep 28, 2005.
  1. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    I'm getting ready to set up my Hydro assist setup and have read lots of technical information on different setups and cylinders. I want to know more from each of you that have a setup, what your specs and any problems associated with your setup. If you have purchased a kit let us know what you think. Also can you list what kind of ends you have on you cylinder. Oh and list the price too.
    Cylinder: 1.5" bore 8" stroke cylinder (brand unknown, Northern Tool only has 2" bore cylinders)
    Hoses/fittings: buy locally 2@ 1/4 4' (what pressure? 2500 running....burst?)
    Steering box: Did you tap it? Where? Any interference? (I plan on running EMS caps) yes iv'e seen the ramcharger site, but I want to see yours or hear how it went.
    p/s pump mods: any? (I found a thread about drilling out the bore slightly larger)
    crossover/highsteer: crossover
    tie rod setup: stock d60 (I hear it won't last long :D ) (is it clamped or welded?)
    Problems: I've heard of many people over stressing their p/s pump, bent tie rods, leaky cylinders, etc.
    Any pictures or other input is greatly appreciated.
    Cylinder:
    Hoses/fittings:
    Steering box:
    p/s pump mods:
    tie rod setup:
    Problems:
    copy and paste :D
    Jesse
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Cylinder: Rocklogic 1.5x8" heims on each end, shaft is bigger then the WTO ram.
    Hoses/fittings:I had bought the rocklogic kit but im not real happy about the lines. They are 2 short for the amount of droop I have, and dont have 90* fittings at the steering box so they stick out and get into the tire easily. They are also small at 1/4" and the fittings are small at AN-4. I ended up buying new hoses and fitting from WTO, the hoses are 3/8 I believe and the fitting are all AN-6. They are also about 1' longer then the rocklogic lines.
    Steering box:I tapped my own box
    p/s pump mods: none
    crossover/highsteer:Crossover
    tie rod setup:1 1/4" Chromo, when I hit the steering stops there is still a little left in the box/ram so it just slightly bows the tie rod, but it being Chromo it just springs right back.
    Problems: Woops I guess I already covered them all :p:
    Here some pics, These are the rocklogic hoses, you can see how the stick out from the box. I started putting on the new lines/fittings last night but havent got a picture yet.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Cylinder: 1.5 x 8 PSC w/hiems
    Hoses/fittings: 1/4" NPT on box, -6AN on lines/ram
    Steering box: stock 2wd with EMS front cap/homemade top cap
    p/s pump mods: none
    crossover/highsteer: x-over
    tie rod setup: sleaved dodge rod (same as 1.5" .250 wall)
    Problems: pretty slow at idle but just fine above 1100RPM (problem with using stock pump), not putting the heims on the same plane casues ram to kick/twist a little
    Comments: The EMS front cap is worth it, the PSC ram is a little "not that special" I would try and use a cheapo ram with new seals for my next one.
    Pics
    I wanted the ram higher than the tie rod so I wouldn't be very likely to damage it.
    Keeping the ram high caused the heims to be 90° off
    The EMS cap allows you to keep the lines away from the tire
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Cylinder: 2" bore 8" stroke tractor tie rod ram
    Hoses/fittings: Custom made 1/4" hoses. Would have gone 3/8's but nobody in town had the fittings and I didn't want to wait.
    Steering box: Drilled and tapped my own.
    p/s pump mods: None
    crossover/highsteer: ORD crossover
    tie rod setup: ORD 1.5" OD tie rod with a weld on tab. Bends slightly when I max out the ram and the
    Problems: Need to adjust the steering stops a little but none otherwise. You've gotta use a little muscle on the street since it's a touch slow but nothing worth possibly grenading my pump for.
    EDIT: Just saw your price list request....
    Tap: somewhere around $10
    Hoses: $50, don't ask, it was a Saturday and I needed them badly
    Ram: $55
    Crossover: $400
    Tie Rod: $115
    Diff Ring and T.R. Tab: ~ $75
    Total in my steering components: around $700
    A picture:
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I got Matt at WTO to do mine a LONG time ago. 2" Ram and we went through an R&D process with several steering boxes to work out a way to keep the lines on top and out of my tires but still working right. The "original" design did not work for me due taps on the side interfering with my 4" lift and 42" tires on 8" wide wheels with 4.25" b.s (net result: my tires are much closer to the frame than most). Basically, the tires ripped the hoses out of the box when twisted and turning. Anyway, I'm very happy with mine other than the fact it's a bit slow. I've had NO mechanical problems with it once the hose location was resolved. I did the "flow mods" to my pump, but it's still too slow below 1000 rpm or so, particularly if I'm on the brakes too (hydro boost). I think if I pony up for a good after-market pump, It will probably be just about perfect...
  6. 81jimmyslt
    Jun 5, 2003
    1,643
    Thanks for all the great responses and pics. Keep em coming.....
  7. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Can you guys post a link to "EMS"? That is some secksy junk! I tried to Google it but got a ton of emergency response type stuff.
    Thanks!
  8. 81jimmyslt
    Jun 5, 2003
    1,643
    meant to put that in my original post but was in a hurry
    http://www.emsoffroad.com/hydroassist.htm
  9. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    im just about done collecting my assist parts.
    2"x8" Northern Tool cylinder
    DIY ram mount
    home ported box (i have a front cap of tapped made of steel and will tap the top cap, sorta like the EMS setup, but only cheaper).
    3/8" x 6' hoses i had gotten as a partial trade with a hydro boost setup.
  10. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    How come no one else does this, it looks ten times simpler then sending your box off to be tapped?
  11. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    Fayetteville North carolina
    im a noob what is hydro boost?
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hydraulic Brake Booster (hydro-boost). Similar to Vac brake booster, but driven by the power steering pump and much more powerful. Typically found on 1 ton trucks, pretty much all diesels, and high end luxury cars like Town Cars (due to smooth and effortless operation I guess).
  13. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Because I tapped my box in an hour with a $10 tap.
  14. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I dont remember prices or specs n stuff cuz I did all of it a while ago but...
    Cylinder:WTO (leaky)
    Hoses/fittings:WTO
    Steering box:my box Tapped by WTO
    p/s pump mods: None
    crossover/highsteer:ORD crossover/highsteer arms,
    tie rod setup:ORD drag link tierod both with w/TREs
    Problems:My only complaint is the ram leaks.
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    How do yall have your lines run?? My wto lines are so long and there pretty stiff, hard to find a good spot that they will work in and not get into the header or oil pan.
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Mine are WTO and you can see how they are routed in the pic.
  17. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Hmm seem slike mine are to long to do that easily. Myabe once I push my axle 3" forward this weekend they will. I have a feeling the headers arnt going to last long....
  18. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Mine seem a bit long.Mine run on the outside of the frame and have heat shielding on them where they run by the exhaust.
  19. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I somehow forgot to take a picture of how my lines are run but they wrap around the front of the box and go to the ram from there. They're outta the way and safe from carnage and I seriously doubt they'd get into headers if I had 'em.
  20. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I absolutely hate headers, nothing but trouble... Still, heat shealding in the form of header wrap, or a sheet metal "tin can" style sheild as used for starters should be enough. Main thing is to block the radiant heat.
    Also, mine are +4" compared to what WTO normally shipped at the time I got mine. Not sure what "normal" is now, but mine are rather long.
