perch width on a dana 60
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Seventy4Blazer, Jun 12, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what is the perch width on a front dana 60 off a 75+ chevy.
    thanks, grant /forums/images/icons/laugh.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    There are no '75 D60's. D60 fronts came out in '77.
    The perches are around 31.5" center to center of the pin holes.
  3. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    31.5" I think?
  4. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    so it should bolt right in on a half ton then?
    grant
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Oh yeah, a direct bolt in. /forums/images/icons/wink.gif
  6. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    k, because a friend of mine has a one ton front axle. he wants to trade me my 1/2 tons for it. i just need to find out if it is a single or dual version. if it is off a dualie how much can it cost to have machined?
    grant /forums/images/icons/blush.gif
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Approximately $200 or slightly more to machine the hub.
    You might be able to get lucky and find someone else who has the SRW hubs and needs the DRW ones and swap with you. Even check out POR and see if anybody over there wants to swap with you.
  8. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    ok, thanks
    one last question, on this subject anyway, who was it on here that ws doing the amchine work?
    grant
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    what was in the one tons before 77 then? and is it a worthy axle?
    grant
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    I think it was Donovan and I also remembering reading that Blazen91 was doing it, too.
    There were no 1 ton 4x4's before '77. 3/4 ton 4x4 was the largest you could go.
    1 tons were available before '77, but only in 2wd configuration. /forums/images/icons/wink.gif
