perches
Discussion in 'The Garage' started by sledheadak, Jan 25, 2007.
  1. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    2.5" wide springs on 3" wide perches...good - bad - ugly????
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I don't see why it would be a problem.
    Also, its spelled "perches" :D
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
  4. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    not good to do. ubolts will not sit propporly if thay rest against the perch and not the springs. but if thay dont hit then dont see a problem.
  5. sledheadak
    Apr 29, 2005
    1,283
    anchorage,alaska
    im putting a d60 and hd d70 under my jimmy and i have to move the perches on the d70.i have some 1/4 wall 3" box steel that i can make a set of perches with.i dont want to order a set for it since they would end up being close to 70 with shipping here and i wanted to make them a little longer to help control axle wrap.i will be running 44s with possibly a supercharged small block.
  6. sweetk30
    Nov 1, 2004
    25,528
    527
    only thing is like ai said ubolts need this ( I I ) 90 degre to every thing. if your perches are to long and wide thay will be ( / \ ) and not stay tight to the axle and springs.
  7. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I ordered my perches from summit, I believe moroso made them in the chassis section. They are 2.5 inch wide for 3" tubes. Summit has free shipping I believe to all 50 states. But they have a 10.95 handling fee. Check it out and see if it applies for you too. THe perches are 19.95 in the catalog.
