Perf RPM, Holley, 700R4 linkage....
Discussion in 'The Garage' started by SUBFAN, Jun 18, 2005.
  1. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    My '90 Burb is getting a new bullet. Switching from the TBI to an RPM manifold and truck avenger.
    Who has used what to help get the linkage and TV cable right?
    Is the added heighth of the RPM going to create a problem?
    I am going to need the ends that can connect with the cables too....
    Help me save me some $$$$
  2. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I am going thru a similar dilemma with my son's truck, '79 350/350TH performer and holley 600. I have found in a JEG's catalog the (I think) correct parts to make the Holley carb work with GM cables. I also see listings for 700R4 kickdown cable bracket JEGS #510-20-95 and the throttle/trans kickdown studs #510-20-40 and throttle cable stud #510-20-38. Check out Jegs online and see if those #'s will work for your application
