Perf. Tire & Wheel Spacers - What Size??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brian 89KBlazer, May 18, 2001.
  1. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Please help! I want to get my Wheel Spacers ordered from Performance Tire & Wheel today & I don't know what to order.
    MY Dana 60 measures 69" & the rear 14ff measures 67". The problem is that the studs are 1-1/4" long so if I go with the 1" spacer, the studs will need grinding. I thought 1.25 would do it but Shawn's article says that the 1.5" spacer he used barely cleared the studs. I don't want to go wider with the 1.25" spacer & still have to grind.
    Is anyone else running these spacers on a 14bolt & if so, what's the minimum size I can use to clear the studs?
    If anyone ground the studs off, was there much to that?
    Brian
    89KBlazer
  2. CK5
    May 19, 1999
    21,623
    701
    CO
    I got 1-1/4" spacers and they clear the studs just fine.
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  3. Brian 89KBlazer
    779
    Ontario, Canada
    Thanks Steve
    I figured they would but that Spickler guy had me wondering!![​IMG][​IMG]
    Time to order!!
    Thanks again
    Brian
