Performance and tailpipe hole
Discussion in 'Other Rides' started by Skigirl, Aug 20, 2001.
  1. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    My other truck (87 Toyota 2WD) has a hole in the tailpipe just past the muffler. I'm now noticing a change in performance that feels like it's "missing" and like there's backpressure building with a decrease in power, then it releases and the power surges.
    I don't understand how the whole exhaust system thing works so am looking for some understanding of this system and an answer to: could these symptoms be due to the hole?
  2. Prembird
    Prembird 1/2 ton status
    May 15, 2001
    811
    kc, mo.
    Not really... The hole is behind the muffler correct.. that means the only thing left is for it to exit out the back... All the back pressure is before the muffler.. As for a loss of power then it comes back.. then goes away... There could be alot of things that could cause this problem.. Is there any other problems you are having???
    Prembird
    [​IMG] <font color=blue> If it aint</font color=blue><font color=red> LOUD </font color=red><font color=blue> Then turn it </font color=blue><font color=red> UP</font color=red> [​IMG]
  3. Skigirl
    Apr 2, 2001
    2,563
    No other problems. The engine is new (less than 6000 miles on it) and my mechanic adjusted the timing less than 2000 miles ago. It's not leaking, no black smoke from tailpipe, no other problems. It was pinging a bit until I switched to the next octane up from regular, now it's OK. Sounds a little louder from the hole tho. Hmmmm, homemade fake flowmaster noise!
  4. Prembird
    May 15, 2001
    811
    kc, mo.
    Well... lets see... if he adjusted the timeing and moved it to far forward that would explain the pinging on lower octane gas... Personally if it was me i would take it back to where you had the motor redone since it should still be under a warranty.. have them find the problem... It could be something internal and hell it doesnt hurt to have them go back over there work...
    Prembird
  5. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Your cat might be clogged up. You can take the exhaust apart from the heatriser in the y-pipe and run it and see if it acts better. If it does, then the cat is clogged.
    It's been lovely, but I have to scream now.
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
  6. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Sounds like it's time for a cat. If your truck has more than 60,000 I would change it.
  7. Skigirl
    Apr 2, 2001
    2,563
    Prembird, I would except it's out of warranty (it's been over a year - I don't drive it much). My mechanic did retard the timing some and it got better, but still doesn't like 87 octane. It's fine on 89. I'll have him check it over again (this is not the same mechanic that did the original work).
    Muddin and DMK. I'll check that. The truck has 132K miles on it. New tranny 20K miles ago. New water pump 1000 mi ago. Otherwise everything in it is original, from 1987.
    Thanks all for the input!
  8. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    If it is fuel injected I would check the oxygen sensor
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
