performance mods for small block (carb, ignition, heads, cam)
Discussion in 'The Garage' started by mudrunner78, May 4, 2002.
  1. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    ok I have a fresh 350 bored .60 over. I have a edelbrock intake, and dynomax headers on this motor, I would like to improve the performance and need a few questions answered. First what carb should I run the holley avenger, or a jet quadrajet.
    Should I leave the ignition stock or upgrade with a petronix kit or MSD 6?
    Heads I know the vortecs are good heads but would cost me to much coin after the cost of swapping over intake and headers. Does anyone run World S/R torquer heads? Or any other suggestions? I am looking for max lowend power, but need some type of mid range.
    And cam suggestions I have my eye on the extrem energy 4x4 cam 210/218 duration 447/.462 lift. I was planning on running 1.6 rockers with this cam.
    I have assembled a few motors but I seem to spend alot of time and money swaping part to get a good combo. I figured where else to get the info I need to help save me some time and money. I am looking for a strong low end motor that has its usable power range from 1000 to 4000 rpm. Thanks in advace Jesse.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I would definitly put MSD on this motor. Use whatever 6 series box you think is right for you, a blaster 2 or blaster SS coil, and a good set of Taylor or MSD wires.
  3. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    I have 350 motor with World S/R Toquer heads Ported and polished runners smoothed out and gasket matched and a Jet Quadra jet that is putting out about 400 h.p. I also run a MSD 6a box. with a recurved Proform distributor This is a great combo and it runs like a raped ape.
  4. mudrunner78
    Sep 7, 2001
    366
    Rocksprings, TX
    I was looking at the 6 Offroad. I know the benifits from longer spark, does this box have a rev limiter. Jesse
  5. mudrunner78
    Sep 7, 2001
    366
    Rocksprings, TX
    just curious what cam are you running in this combo. Jesse
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    No it doesn't come with the built in rev limiter, but it does have a special waterproof/vibproof rev limiter that you can buy seperate for around $70 threw Jegs or any other place. I love my offroad box, and wouldn't even think of not running an MSD setup on a HIPO engine like you are building.
  7. mudrunner78
    Sep 7, 2001
    366
    Rocksprings, TX
    I have used MSD products before but those where one track motors. I hear alot of good things about the HEI at low rpms. HIPO motor haha. Jesse
