Perpetual Choke Light??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Nov 8, 2000.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    My choke light never goes out (ign on) in my '84. The choke operates fine and has 14 volts going to it. I'm sick of waiting for the bulb to burn out. Thanks Luke
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I see my choke light come on once in a while too. Mines an 81 Jimmy. On mine I just turn the key a little farther and the light goes out. I just figured "whatever". If that doesn't work remove the bezel and remove the choke light.[​IMG]
    Rene
  3. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    This may sound silly but check all the fuses, my sister has an '80 Camaro, and the oil light was always on, well after stareing at the wiring diag. for four hours i finally figured it out, a fuse blew, and the choke is wired through (0n that model) the oil pressure sensor, so there was a ground backfeed through the choke, through the sensor to the light, replaced the fuse and boom out it went, the choke worked, since it was getting power from the inst. panel but it worked better when i fixed the problem, Just a thought.
    RaisedK5
    "Friends don't let friends drive Fords"
  4. Scottsdale
    Scottsdale Registered Member
    Nov 6, 2000
    9
    South Carolina
    Mine won't go off either. It started after I put a set of mechanical gauges on. I just left the wiring for the old oil sensor tied to the frame. I'll check the fuse though.
    Bowties, hate wearin' em, love driven' em!
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I've heard its got something to do with your oil, whether its low pressure or low amount. Might be worth checking.
    creepin' and crawlin'
    Jim
  6. Cavalry
    Oct 1, 2000
    978
    Mine started doing this trick after having the carb off to rejet. Put it back on and the light never went off again. As far as pulling the bulb, I'm not going to make any special trips to pull the cluster, If noone can come up with a fix I'll wait till it burns out or pull the bulb next time I have the dash tore out.... Who the hell really needs a light to tell them the choke is on? What exactly is the purpose of it?
