Perpetually leaning K5 syndrome
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Sep 2, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Ok... here's the deal. Bryan's rig is leaning to the driver's side quite a bit. His rear springs had cracked... the drivers side cracked in two places, and the passenger cracked in one place. BOTH were sagging, but more so to the drivers side.
    We have since replaced the springs in the rear (thanks BIGJ!) yet the truck continues to sit crooked.
    The question here is, WTF! /forums/images/graemlins/angryfire.gif I have racked my sorry little brain over this issue for a week or so now... and I can't come up with an idea thats worth any salt.
    #1. Could the front springs have been "damaged" while the rear springs were sagging, causing THEM to now lean... which would also show up in the rear of the truck?
    #2. What would cause the truck to lean if its COMPLETELY unloaded, just sitting there?
    #3. We've contemplated binding of some sort due to his front flanges (vs. hubs) on an open carrier 60. I don't buy it.
    #4. We've contemplated binding due to the Detroit that we recently installed. It doesn't seem to ever UNLOCK /forums/images/graemlins/angryfire.gif, therefore it tweaks the suspension @ every turn. Possible?
    #5. We're loosing our minds, and its really EVERY OTHER car has a lean... and they need to check their sh!t... not us.
    Any ideas? /forums/images/graemlins/blush.gif Thanks again all! /forums/images/graemlins/thumb.gif
    -Dan
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Measure from level ground to the frame at each corner, then measure the body at the same points. If the difference between the measurements side to side isnt the same, then it could be a body mount bushing or even the subframe (dont know if thats the correct term) is giving way from rust or hard wheeling. Hope this makes sense.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Frame could definitely be tweaked from having jacked up springs so long.
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Tyler-
    Makes plenty of sense, but the lean is in the frame. The body and the frame lean at the same rate. I am fairly sure the body is relatively straight as well.
    Tim-
    Yea. My only question at this point is then... How long should he expect to have to deal with this before it straightens itself out again? It really is PRETTY DAMN crooked... so its fairly annoying. Even to me... and its not even my damn truck!
    -Dan
    -Dan
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Mine does the same thing and I put new spings all around and it's still that way... /forums/images/graemlins/angryfire.gif /forums/images/graemlins/confused.gif
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/angryfire.gif
  7. CK5
    May 19, 1999
    21,623
    701
    CO
    I would check the front springs real close. /forums/images/graemlins/thinking.gif
  8. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Is Bryan by any chance a man of... errr, exaggerated proportions? /forums/images/graemlins/crazy.gif </font>
  9. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    How would one "check" the front springs? Lets immediately rule out the front springs being cracked, or anything else extreme like that. They have good bushings too.
    Keep in mind, the rear leans more than the front. /forums/images/graemlins/confused.gif
    -Dan
  10. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Bryan weighs like 2 pounds.
  11. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Not to mention he's about 6'1"... I think he actually tips the scales somewhere around 160-170ish... so NO, he's nothing the suspension should whine about.
  12. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Take all the springs off you burb and throw em under his K5 for a day on the weekends...If it straightens out...its the springs...if not, look at bent or damaged shackles (bushings toast? etc). Then I would start looking at the frame for cracks or twisted x-members...
    Chris
  13. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Does it lean this bad??? [​IMG] /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  14. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Sounds like a bent frame or crossmember issue. Has it been wrecked?
    I figured the springs would fix it. Guess it's time to break out the tape measure and start comparing sides.
    BIGJ
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Tim-
    -Dan
    I'll have to ask my buddy Jason the next time I see him. He let one of his 44" Ground Hawgs go flat and left it that way for several months and his frame got fairly tweaked. I wonder if it's straight even now, that was probably two years ago.
  16. CK5
    May 19, 1999
    21,623
    701
    CO
    Well that rules out that I guess. /forums/images/graemlins/thinking.gif My passenger front main leaf spring is bent up and it makes the drivers side rear a little lower is why I said check the front springs.
    Are you looking at it before you start drinking or after, that makes a big differance? /forums/images/graemlins/rotfl.gif
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    In that case just drink until the truck looks straight.
  18. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    HA, /forums/images/graemlins/rotfl.gif For once I agree with you! but i still don't like you.
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't care personally if you agree with me or like me. In fact, I'd prefer that you don't.
  20. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I am just tired of arguing about everything.
