PERSISTANT CODE 43
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Mar 10, 2001.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    STILL HAVING A PROBLEM WITH A CODE 43 KNOCK SENSOR, AND I HAVE TRIED REPLACING THE ESC AND THE KNOCK SENSOR. I REPLACED THE GEARS TO GET BACK TO FACTORY SPECS ON THE ENGINE, WITH 33-12.50 TIRES, THINKING MAYBE THE THROTTLE POSITION SENSOR WAS MESSING UP THE SENSOR, BUT IT STILL SHOWS UP, BUT IT IS INTERMITTANT IN NATURE. ANY ADVICE ON HOW TO CORRECT THIS VERY ANNOYING PROBLEM? WHEN THE LIGHT COMES ON, THE TRUCK RUNS REAL ROUGH AT LOW RPM.
    THANKS
    CHRIS
  2. jpdrake
    jpdrake 1/2 ton status
    Oct 31, 2005
    381
    mass/ cape cod
    im having the same code, problem "rough at low rpm" any advice?
