Persistent oil leak
Discussion in 'The Garage' started by skink4president, Feb 4, 2006.
  1. skink4president
    skink4president Registered Member
    Mar 5, 2005
    79
    orlando
    HELP! I've just about lost it over this one. A few months back I dropped the oil pan on my '73 k5 (350/350) to replace the rear main seal. While I was at it I dropped in a new pump, pick-up and new stock oil pan (the old one was beyond recognition). Almost immeditately after getting everything back together the pan-to-timing cover seal starts to leak:mad:. Because it's a '73 I used the thin front seal not paying attention to the fact that the previous owner had thrown on a crappy aftermarket timing cover that I was told uses a THICK front seal. So. . . . . I drop the pan again and throw in a thick seal. Thing still leaks:mad::mad:. So I junk the old chrome timing cover in favor of a new Edelbrock aluminum one with the idea that it'll be more rigid and contains no welds. Guess what. . . . thing still leaks:mad::mad::mad:!
    Now I'm thinking of going with a one-piece gasket for a change of pace to see if it helps. I'm installing the gaskets properly and torquing the pan to approx. 12 ft. lbs.
    Any ideas???? Typically I wouldn't mind a small oil leak but it's gotten personal:D!
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    did you use RTV at the corners?
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Agreed
  4. skink4president
    Mar 5, 2005
    79
    orlando
    Yeah, I RTV'd the corners. Followed all the rules to a T. Is there a difference between a '73 pan and a '74? As far as I know early SB is early SB but up to '73 they used the thin front seal and after the thick. I fugured this had to do with the timing cover and not the pan. I think they changed to the thick front seal so the TC could be replaced without removing the pan (that's what some old mechanics have told me:))
  5. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Use a felpro one piece oil pan gasket. No leaks and its reusable:D
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I'll second the one-piece felpro unit. That thing is the best oil pan gasket I have ever used. Its like a piece of art....wait a minute, its a gasket. Oh well, it is nice, and it doesn't like to leak.
  7. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    go through some mud :dunno: that usualy stops my leaks :burb:
  8. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    You might try torquing it to more than 12 foot pounds. I usually go about 20 foot pounds. I know 12 pounds is the recomended, but I have never agreed with that.
  9. skink4president
    Mar 5, 2005
    79
    orlando
    Thanks to everyone who posted.:waytogo: I'll grab one of the Fel-pro gaskets this week. BTW - I'm using those $60 :eek1: Fel-pro valve cover gastets. I know it's a lot for valve cover gaskets but the things are great (silicone, compression limiters, reusable, etc) and put a stop to those annoying leaks!
  10. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    I didn't know they made those. I'll have to do a search and find some. I've been battling valve cover leaks for a long time....
  11. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    It costs me 55 bucks each, but I will NEVER touch another multi-peice oil pan gasket ever again!
    Those felpro silicone gaskets are simply incredible!
