Pete Jackson gear drive?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Jun 13, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    I was just toying with the idea, but would it be stupid to put a Pete Jackson gear drive in my truck? Maybe it's just me, but I think it would sound sweet roll'n up with your engine whining. Then I could tell everyone I have a BLOWER! hahaha They aren't really expensive and heard they work really well.
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    From what Ive heard from the guys at a local speed shop, its not worth it unless your motor is really, and I mean really built up. They told me it costs 20 horsepower for the sake of better cam timing. I guess the extra friction from the gears is where you lose the horsepower. Now, these guys could have been wrong, so anyone who has heard different please correct me.
    Tyler
  3. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    I totally agree with BlueBlazer62. If you want to spend the money and the time for installation to gain some noise and lose approximately 20 hp, then go for it. But, they are really meant for high rpm, high compression engines with a roller cam, where cam timing is critical and a chain drive won't do. Absolutely nothing wrong with running a gear drive; it won't hurt anything, but will cost you some hp.
    502Burban
  4. Motoronbrain
    Motoronbrain Registered Member
    Jun 12, 2001
    58
    Washington
    I put in a Cloyes gear drive and did not notice a loss of horse power. I think it sounds cool too.
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>You cant run a gear drive on your motor. The knock sensor will pick up the noise from it and the computer will retard your timing. </font color=blue>
    [image]http://bbs.off-road.com/wwwthreads_uploads/53-288682-mudpit3.jpg[/image]
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    big gray is right. It will screw up the computer. It does cost HP to run and also you have to remember the "whine" is from the gears. this whine is harmonics. I have heard(several times) that you should only use these with steel cranks and good balancers. Harmonics kill!! and should be avoided. I have used them in several engines that I have built, But they also had steel cranks, fluid dampners, roller cams and many other pieces. I have never used one on a stock engine, or would I recommend one. But I gotta agree, I think the noise is cool!!!!!!
    your right. I don't understand the jeep thing!
  7. Motoronbrain
    Jun 12, 2001
    58
    Washington
    I keep forgetting that they made Blazers with all the new do dads on them. I have a 71 with a pretty stout small block in it. It also has a steel crank in it. I have never had anyone that I know of put one on a cast crank. I would hope that on companies stand point, such as Pete Jackson that they would warn you about the problems with installing it on a cast cranked motor if it is a problem.
