Peterson's new long travel leaf article, read this?
Discussion in 'The Garage' started by sled_dog, May 25, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Peterson\'s new long travel leaf article, read this?
    Read it today finally. Seems like a large waste of time to me, should have moved the front mount forward instead of moving the rear mount back and lower.
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    Re: Peterson\'s new long travel leaf article, read this?
    I got to get the new issue...
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    At least they used ORD parts /forums/images/graemlins/thumb.gif
  4. wfo163
    wfo163 1/2 ton status
    Jan 11, 2003
    100
    Charlotte, NC
    Yeah it didnt look like a well thought out modification. Help me figure out what they did with the rear bushing. They didnt say what they used, beside a 1 3/4 inch hole saw to support the in frame bushing? Seems to me that they must've welded in a piece of tubing or boxed that area of the frame. Also wouldnt front shackles that long be awfully week, even at a good thickness. If I recall the author said they were 8 inches long! Just my thoughts, should have just linked it up and run coilovers.
  5. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    I guess they never want to replace the engine. It looks to me like they welded the shock hoops to the frame and the support to the hoops. Do they plan on dropping it out the bottom? It seems to me the spring packs were awfully thick too.
    The thicker the pack the stiffer right? or wrong? It seems to me a guy would want to go with as little and as long as possible.
  6. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Those spring packs are thick, very thick, but look at the leaves, look how short and thin they are compared to say a 1 ton pack. The deavers they used flex like no other spring ive seen. They are simply the best leaf spring I have ever seen and plan on purchasing a set soon. Yeah they go against what everyone seems to think works on this website but i bet the deavers work a helluva lot better than whatever anyone on this site would say to run instead of the deavers.
  7. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    To captialize on what zcar said, a thicker spring pack doesn't always equal higher spring rate. Take a close look at the leaves, Deaver uses a leaf that is approximately 50% the thickness of the thinnest leaf avalaible from the mass producing spring companies. Deaver has built their reputation from building springs for desert racers, they filled a void that National Spring created by offering a great product with great service. In the last year or so, they have branched off and done some springs for rockcrawlers and the results have been excellent. I've heard said that a National spring pack will go maybe a season before they start to sag, whereas there's racers that have been running a Deaver set for for race seasons with no problems.
    As for price, they are expensive, cause they don't mass produce packs, except for a couple of niche markets (Rangers and zcar, correct me if I'm wrong, Toyotas) and these packs still carry a hefty price tag, but from everything I've seen and heard, well worth the price.
  8. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I haven't seen the article yet, but the springs you described sounds like my Alcans. It has about 10 thin leafs, but equates to one thick ass pack.
    Flexes extremely well. You definately need some type of traction bar setup in the rear...
    Boss
  9. mister b
    mister b Newbie
    Dec 15, 2003
    3
    Phoenix
    "Read it today finally. Seems like a large waste of time to me, should have moved the front mount forward instead of moving the rear mount back and lower."
    It seems like an aweful lot of custom fab work for leaf springs. I wonder how much better the long springs work than a set of normal Deavers would have.
  10. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    If the long springs are stock, or a mass produced spring, the Deavers will beat it no problemo.
  11. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    OK quick question for you suspension. Why did they run dual shocks on something designed to be flexy? Were they just really soft shocks or....? Where can you buy the deaver springs at?
    Do you think we should write to petersons and tell them the easier wayy to do this swap? /forums/images/graemlins/rotfl.gif
  12. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Dual shocks should not effect how "flexy" the suspension is. I run a single but I realy need to run a dual set up so I can try to control the body frommovingsom much. I am just lazy andnever really gotten aroundto that fix.
  13. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    what he said.
    all a shock is supposed to do is slow down the up and down movement of an axle it does not change how much movement is there.
    I run king 2 1/2 inch w/remote resorvoir shocks and each one probably equals to about 3 regular shocks because of the dampening.
    someone posted up about the deavers having more flex than anything that someone has on this site. that is not true they do work very well and flex extremely well but they are still a leaf spring. they didnt reinvent the wheel they just made them last longer and not fatigue as quickly as others.
    no matter what you do you will find the limitation of a leaf spring. they can only flex so far and still hold the vehile up.
  14. mister b
    mister b Newbie
    Dec 15, 2003
    3
    Phoenix
    It would be interesting to see a comparison between different lifts. I'd like to see tests of:
    1. TC EZ Rides
    2. TC HD springs
    3. Stock length Deavers
    4. Longer Deaver spings.
    5. Longer "stock" springs, e.g 57" Fords.
  15. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Cool thanks. /forums/images/graemlins/waytogo.gif
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    If I were to keep the K5 I would go with custom springs over say 52s. But I wouldn't do this. The center pin is moved forward form stock on the springs they used, and they are longer than the Alcans I know Pete(Yunit) runs. What is the purpose to that much extra spring material behind the center pin? Yes they didn't describe how they fixed the shackle mount to the frame and I found that very stupid, and yes they welded the shock hoops together preventing you from ever removing the engine without starting over as far as those go. These things are why I say its not a well thought out mod. I agree custom springs are the [darn], they just didn't do a great job of it.
  17. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Deaver doesn't make a lift persay. They mostly custom build the spring packs to the vehicle. The only thing that I know that they have somewhat massed produced has been packs for Rangers and Toyotas, and probably F-150s.
  18. zcarczar
    Feb 10, 2002
    2,495
    Deaver only mass produces springs for yota's, super duty's, a couple 63" chevy's, rangers and f-150's
    I like how they did the setups on that truck, sleddog, there are a lot of problems associated with moving the front mounts forward like I did. So far my frame has cracked again, i had to redo my front bumper and have more frame flex.
    They run the dual shocks for more dampening ability and less fade, not for a stiffer suspension because the springs were designed right. The deavers and shocks are setup as a complete package, not as a bolt on unit like mass produced after market springs.
  19. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    201
    Colorado
    Long tail springs are not an uncommon thing. I can't remember exactly why they are good to have. I think it might have something to do with Pinion angle throughout the travel.
    I welded the cross bar in over my motor in the buggy. The plan with this stuff is usually to just get it done the first time then sawzall it out leaving enough material to add bolt plates to the ends. This way you get the cross bar put in fast the first time since it is probably the 12th hour of the build and you can easiely reverse it.
