phoenix area 14FF drum parts & Radiator
Discussion in 'Rocky Mountain Region' started by Jason4x4, Mar 30, 2007.
  1. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    I am finally doing the disc brake swap on my FF, if anyone needs the backing plates, drums, shoes, or ebrake cables(they are the bolt on ones) let me know before it get's tossed.
    EDIT- going to scrap on friday, also have a 3 row radiator out of 83 chevy. Not the best shape, but works, could use a cleaning, GONE
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Off what year axle? I have a 70's axle in an 80's truck so the ebrake cables are wrong.
    Harley
  3. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    no idea of the year, but they are both short, same length I think, and they go to a bracket on each side of the frame.
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    They sound like the ones I have. I'll pass.
    Harley
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    My K5 has the cables cut off, but like Harley, it's a late model cable I need.
    Also, which size drums? My son ran a wheel off the K5 a year or so back and it warped a drum every so slightly when it hit the road. I could use a drum, if your's will fit. This is a 3/4 ton, and IIRC, that should mean a 2.5" drum.
  6. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    the shoe's are 2.5 that were on it. if you want one let me know, I think I am going to use one for a base for my drill press stand. I am near 101 and elliot. let me know.
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Remember there are 2 different size 3/4 ton brakes. 13" & something smaller like 11.5". They are both 2.5" wide but the drums are different size. Harley
  8. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    They are the big 13" ones, thanks harley.:waytogo:
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'll check mine tomorrow, but IIRC, they are almost all 13".
  10. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    Russ, you have 13" brakes.
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Thanks, I thought so, but wasn't going to state definitively without checking.
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    After 83 , they changed the routing on the truck from a bracket on both sides to a bracket on one side .
    All the various trucks I have had here have been the same length cables , except Shawns 86 which had none .
    Which corresponds to these pics from the LMC cat :
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ahhh, good to know that '84 up (if I understand "after 83" correctly) is what I need.
  14. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
  15. VikingWarlord
    VikingWarlord 1/2 ton status
    Sep 25, 2005
    293
    Flagstaff,AZ
    Thanks for the radiator !!!!!
