Phx AZ - I need ...
Discussion in 'Rocky Mountain Region' started by AZ79K5Project, Nov 4, 2006.
  1. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    ...Two things
    I am picking up a 14bff w 3.73 gears. I need to regear my 10b from 3.08's and also change it to an 8 lug. I have read tons where shops will charge around $100 labor to regear if I have the parts. I have been quoted $600 at one place and $1100 at another. Anyone have a line on a good shop that will do the labor?
    Also, new rotors and calipers are cheap, but I can't find 3/4 ton caliper backing plates. Anyone have any laying around, or know of any place to find some?
    I was on Broadway and Lower Buckey all day with no luck.
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    This would be extremely cheap....
    Have you thought of just buying a whole front end that is already geared @ 3.73? It was a very common ratio and it seems a waste to spend money to regear TO that ratio.
    I have a D44 front that is 3.73 - but it's 6 lug....:(
    Marv
  3. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    I went to north Phx today to get a 10b - 3.73 setup. I got there checked it. It was geared at 3.08.
    I would be happy getting another axle already geared, but I'm having trouble finding one that someone isn't really proud of, if you know what I mean.
  4. blaza
    blaza 1/2 ton status
    Jun 11, 2004
    158
    Tempe AZ
    $100 is CHEAP. $600ish parts and labor aint bad.. Gears are time consuming and icky so nobody wants to do em for nuthin. Hell its only the front, have you thought about doin it yourself?
  5. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    I thought about it. I have never done gears or have even seen it done. I have read a couple of write ups, that's about all when it comes to regearing.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Think it would be better if you just do some junkyard hoppin, and see what's out there, usually you can get a complete front diff for around $150...
    I have a front axle here, not sure of the gear ratio yet, haven't pulled the cover yet, it's from a Dodge, has studs on the pass side spring mount area, (similar to D-60 style) but it is 8 lug, and i believe it has flattops.
    Really don't think the complete front axle would be something anyone wants, it's a weird style, it has some vacuum actuator on the long side for something, i was told for engaging and releasing that axleshaft or somethine, don't know, as i said, i have not torn it apart yet to see what this thing is exactly...
    Rotors are junk, but everything else is decent
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yep, it's called CAD for "Central Axle Disconnect". That's what they did for a while instead of locking hubs but it results in more wear since the diff and shaft are always turning, but it lets you turn on pavement like it's unlocked...
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    This particular 14 didn't happen to be delivered in a white CC-SB PSD driven by a fellow with the intials TZ, did it?
  9. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    No. First initial P.
  10. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    I will be picking up a 10 bolt axle with 3.73's in it here on Tuesday but it's just a 6 lug. Let me know if your interested. I will be in phoenix on Saturday morning.
  11. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    I asked 'cause I just sent one that way. Figured it was a long shot though.
  12. mtnman
    mtnman Scrap metal fabricator Premium Member
    Sep 8, 2005
    2,087
    31
    On the farm , Missouri
    I have a perfect set of late 70's backing plates that have been cleaned and painted SUPER nice (dark grey metallic) and I would let them go cheap. Make me an offer. I'll be in the valley Thanksgiving weekend.:D
  13. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Let me know the condition and price, I might be. Thanks
  14. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Thanks for letting me know. I may take you up on it depending on what happens tomorrow. I finally tracked down the 12 bolt rear rather than a 14bff. I wasn't able to meet up with the guy with the 14.
    I have new 33's on 15's. I need to see how things go with wheeling down in the Valley with the 10 and 12 before I build up. (60/14bff) If I break stuff, well you know the deal:crazy: $$$$
  15. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    Sent you a pm give me a call before Saturday.
    Here is one pic that was posted let me know and I will take some more for you.
  16. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    mxfireman: Just sent you a PM
  17. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    OK here are the pics as promised. Confirmed it 3.73's Also pauly383 needed the rims is that ok with you? I kinda promised them to him before we talked about it?
  18. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Looks good. I posted the question about Tempe in the other thread:
    Meet and Greet
