Pic of 52" RTI Test
Discussion in 'The Garage' started by DougK20, Feb 8, 2005.
  1. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Well, here she is. First time up the ramp on the new 52's. Didn't bother to score it. Just check'n everything out. Did measure about 22" overall wheel travel. Net about 6" lift.:waytogo:
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    very nice. Those DT shocks? look close to maxed out.
    Lil bit of negative arch on the drivers side. Whats the plan with respect to bump stops and limiting straps?
    j
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    looks good :waytogo: what's the travel on the front shocks and the lenght of those brake lines?
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    agreed... what brake lines are those? length? cost? DOT-approved?
    j
  5. DougK20
    Feb 18, 2003
    384
    Boise, ID
  6. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
  7. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    cool beans. the brake line look pretty long do you happen to know how long they are?
  8. DougK20
    Feb 18, 2003
    384
    Boise, ID
    They are roughly 26" long, and YES, they are DOT approved!:woot:
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Do you have the front driveshaft in that thing right now? Is it the stock shaft? Have you checked if the CV is bound up at full droop. Did you clearence the CV to make it have more angle? Is there enough spline engagement for that amount of flex?
    Harley
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    if it's stock, it's binding and has come apart. I'd imagine it's not stock.
  11. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Looks as though the spring pack is not totally bolted onto the axle? Looks very impressive though.:cool1:
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I realize that, that is why I am asking the questions. A stock driveshaft can be ground down quite a bit to get a fair amount of angle out of it but I don't know if it will get that much angle for that amount of droop.
    Harley
  13. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    That's what I though also. Maybe we are looking at it wrong? Or it's a new trick?
    What do you have for steering?
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    :eek: if that's not space, i dont know what is!
  15. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    looks like a zero rate to me :confused:
  16. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    There's a zero rate there, hi-rez monitors work wonders.
  17. DougK20
    Feb 18, 2003
    384
    Boise, ID
    My next project is clocking the t/c. Then, I will ramp it again to measure for a new Tom Woods long-slip shaft with his new high angle u-joint. (need to win that giveaway!) My pinion measured out very well with a 4deg shim. Sorry, the stock shaft would never work.....
    Yes, it's a zero-rate. (sorry for the dark photo) I have it pushing the axle back 1.5". My wheelbase stayed the same before & after.
    BTW, somebody asked.... the brake lines were around $99.
  18. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Looks like you're in the 1100 range..... :thumb:
    When the front hubs are aligned with the start of the ramp, that's 1000. You look to be at least a foot beyond that point in the pic.
    Wish the pic was a little brighter, and from a few more angles. You can learn a LOT about your suspension by ramping it and studying the photos carefully....Shock lengths, driveshafts, bumpstops, fender clearance (or NOT!), etc.
  19. DougK20
    Feb 18, 2003
    384
    Boise, ID
    The best I could ever do with my 4" Tuff Country E-Z Ride Springs was a score of 970. I told everybody that if it didn't do any better with the 52's, I was going to be pissed:haha: I'm glad it did!
    Thanks to my neighbor, Kevin (TwistedJack) for letting us use his ramp. You should all be so lucky to have a neighbor like him! Though, he would make fun of my "celebration post"....:pimp: You ROCK, man!
  20. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Why Tom Woods? I've heard nothing but bad about the man and shop myself. I know I'd go with HAD, but if you have your reasons thats cools.
