Pic of the new project - big pic.
Discussion in 'The Garage' started by DPI, Dec 9, 2004.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Pic of the new project Rockwell Install - big pic.
    So far I've got the rear Rockwell spider gears welded up, the 63" 3/4 ton rear springs in, and the 4" ORD shackle flip installed.
    This setup has already netted me 9" of lift in the back. This may be to much with my 46" Michelins. Those are 41" tires on there so I can move it around if needed.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Can you post a pic of your rear spring hangers?
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I know Rockwells have their disadvantages but I still smile thinking about puting them under my rig.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    The flip is bolted on the rear crossmember. 2 sets of bolts on each side of the crossmember. I used a bushing to bolt the flip to the bottom part of the frame since the frame is not flat there.
    There is no weight in the back. And the tank is removed. Once weight is added to the back the shackles should be at the correct angle.
    I love the idea of Rockies too. The fact that the driveshaft is way above the rocks is a great benefit...
  5. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Can't wait to see it when it's done Dan.:D
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    That looks like your going ot have some fun! Now you got me thinking about reworking my rear suspension.
  7. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    hey, i have drove that blazer before :)
  8. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    good work
  9. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Is there any blazer you haven't drove or owned? BWAHAHAHAHAHA
  10. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Holy moley! Thats an interesting looking axle!
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what are you going to be doing about axle warap? ladder pbars? (with 46's and rockwells you have a little ground clearebnce to spare) or a antiwrap bar? dual or single?
    looks good. im thinking on rockwells for my 74, but i have to buy another blazer first.
    grant
  12. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Oh, I forgot to mention, I gained about 2" of ground clearence by shaving off the bottom of the diff pan and replacing it with some 1/2" steel plate...
  13. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    I am planning on a single anti-wrap setup per axle. I am thinking about mounting it to the side of the worm gear box. Hopefully, with the flat 5-leaf 3/4 ton 63" springs, there won't be as much wrap as with heavily arched springs.
    btw, I have a '90K5 1 ton for sale...
  14. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Sounds a little backwards to me. The heavily arched springs are usually stiffer and will help control axle wrap... not create it.
  15. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    It sounds that way but what would be easier to bend, a straight piece of steel or one that has already been bent (arched)?
    These springs are pretty stiff. They are the 5 leaf with an overload.
    We'll see, this is a trail and error type of thing anyway. If something doesn't work, then I'll try something else. That's half the fun, isn't it?
  16. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Well, think of stock springs... flatter, more flexible... more axle wrap problems.
    Lift springs, more arc for th elift, worse comfort rude... less axle wrap.
    :cool:
  17. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    look real good. im running 63 also, i moved my ord shackles brackets back so the front holes lined up with the rear holes, only had to drill one new hole and drill out two for 1/2 in bolt and slot one hole a little. moved the front bucket the same using the stock hole span bottom frame bracket that rivited to front bucket and redrilling new holes. as far as that bump on the bottom of the frame,i pie cut a small sliver out of the side of the frame leaving the frame radius, cut the bottom across where the hole for the body bushing is ,hammered it up, welded it up and added a gusset at that point, frame is flat now.
  18. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Pictures?
  19. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    NICE! That is going to be a BIG ****ER!!!!
  20. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Yeah, I am very surprised I got that much lift out of the 63's and flip. My goal is to keep the center of gravity as low as possible and still fit the 46's. Some minor fender trimming was done to this by the previous owner - Thanks OL14BLZ!
