Pic of the new Super Swamper IROK
Discussion in 'The Garage' started by nvrenuf, Apr 15, 2003.
  1. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    Looky..looky
    I don't know anything about the tire, I found this pic on another board and thought y'all would like to see it.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Cool looking tire, but it seems like it's directional more for the form than the function. I'd rather have a non-directional tire so I can rotate it to the other side of the truck... </font>
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I'm not sure if this tire is a radial or bias design, but if it is a radial tire, you DON'T want to swap it to other side - directional tread or non.
    It looks like an interesting tire. I'm not too crazy about the design, but I'm sure it functions well. Those are some pretty big voids though...probably really bad wear/mileage out of them. /forums/images/graemlins/smirk.gif
  4. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    I bet that dude is LOUD! /forums/images/graemlins/shocked.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/shocked.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    This was true about 30 years ago. However, I'm not aware of any tire manufacturer these days that still recommends that you never change the direction of rotation of their radial tires. Many early radials would self-destruct if you changed the direction of rotation on them, but they solved this problem long ago.
  6. heavy4x4
    Aug 28, 2002
    3,270
    I agree...I haven't heard manufacturers saying not to swap sides anymore, but I've read accounts of a few people on here (that swapped sides/directions of their radial tires) that the noise level was increased significantly and the ride was harsher/bumpier. /forums/images/graemlins/confused.gif
  7. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Most likely due to 'breaking in' the tire to run the opposite direction. This situation would be more pronounced if the tires have worn poorly (cupping, out of alignment, etc.). Tires that get rotated regularly and are wearing evenly will only produce this effect for a minimum amount of time/milage, if at all.
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I don't think the flying apart is a concern anymore. OTOH, I tried swapping my BFG M/Ts in the old bias pattern to even things out &amp; they got very loud. I also did it w/ the Michlens on my Jeep and while they were any lounder they did take a while to smooth out. Just my $.02
  9. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I've heard that you can swap side to side if you rotate regularly, but if you run a tire for too long in one direction then the belts end up set too hard to be able to be run in the other direction. I've actually tested this theory, but not on purpose. Around '94 I rotated a set of BFG T/As side to side after running in them in one direction for about 20k miles. After about 3k miles running in the other direction the tires were hosed, the tread was all deformed and lumpy on every tire. I usually rotate my tires every other oil change, so every 6k, and have never had a problem with that interval.
    That being said, if you care about rotating your tires, then odds are you do it often enough that you won't ruin a modern radial. When I rotated the previously mentioned BFGs I was just bored and looking for something to do, so I rotated my tires.</font>
  10. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Harry
    I'm in agreement with what you have said; I've been doing the bias-style rotation for years on my car with no apparent loss in treadlife or uneven wear. However; in regard to what manufacturers say; here's a quote directly from Interco's website about tire mainteneance &amp; causes of wear......just found it interesting.
    _________________________________________________________
    "It is recommended that tires used on four wheel drive vehicles be rotated front to rear and rear to front about every four to five thousand miles...don't criss-cross."
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I had the same problem with several BFG AT's in the '93-'94 timeframe, but they hadn't been rotated to reverse their rolling direction. After I asked the guys at Discount Tire what was going on, since they had warrantied out 3 of the 4 tires on my truck for separated belts, they warrantied all 4 BFG's towards a set of their Pathfinder AT's. Those never gave me a problem. /forums/images/graemlins/cool.gif
  12. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I like it /forums/images/graemlins/thumb.gif
  13. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I'll have a set of their 39.5"x13"/15" IROK tires within a week. I'll be sure to post pics and any info I get. /forums/images/graemlins/thumb.gif
  14. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Neil, do you have any other info on them? What sizes are going to be available?
    They look like a blend of a TSL (center section) and a bogger (outer lugs)
    Rene
  15. CK5
    May 19, 1999
    21,625
    702
    CO
    36x13.50-15 I-801 in stock
    36x13.50-16 coming soon
    36x13.50-16.5 coming soon
    36x13.50-17 coming soon
    36x13.50-20 I-805 in stock
    39.5x13.50-15 coming soon
    21/49-17 coming soon
    24/49-20 coming soon
  16. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    [/ QUOTE ] /forums/images/graemlins/eek.gif
  17. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Steve you have any specs on these tires ie. load range, overall dia., rim width and weight?
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  18. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I haven't seen any of these in the 4wheeler ads or anything? What are they running for $$?
  19. Mudzer
    3,639
    Missouri
    Interco said they will have excellent forward traction, much better lateral traction than a Bogger and should stick to rocks like glue. /forums/images/graemlins/thumb.gif Mine will be a Bias type.
    They did not pull out any of their drag compounds for many reasons. We have talked at length about this subject. We've been chatting for a year about this tire.
    This was the first time I got to see the tire in a pic - I've been begging Interco to email me a pic. Guess Matt had no choice but to release the photo - But I was told to keep this on the down low. Looks like its no longer a "secret". /forums/images/graemlins/grin.gif
    It looks like they are on their way to designing the "Ultimate Tire".
    You will notice the push to have the larger rim sizes. This is for reasons as Fox stated a while back. Less sidewall to damage. Look in the future to see the other lines have new rim sizes. Looks like the IROK will be a Full Line tire - meaning they will eventually make all of the popular tire/rim sizes. /forums/images/graemlins/thumb.gif
  20. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Looks like a competitor to BFG's new "Krawler". What are the $$$ on these in the 36x13.5x15 radial? I priced the comparable Krawler @ $237.50 per tire.
    John
