Pic request 6" with 37's Little or NO trimming
Discussion in 'The Garage' started by MTBLAZER89, Mar 22, 2006.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Just want to get an idea. I am thinking about swapping the 37's onto the crew cab just for fun. I need to grind the 60 for them anyway since it is going under the K5:wink1: I don't want to trim the pickup fenders. It has already been clearanced a little (that lip on the bottom is folded inside the fender, but you can't see that part. I know they may rub a little, but let me know how much. This truck won't be wheeled at all just driven back and forth to work. Let's see them:D
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Take a look at my crew cab in the ck5 galley, I've got 6" Rough Country w/ 35 BFG's on 12" wide Welds and no trimming at all. Mine will rub a little in a turn if I hit a bump/curb.
    Next time I intend to go with a wider 36 but I'm afraid that'll force me to use a 1" body lift.
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yes I know of your truck:wink1: It's what started my V3500 fascination:D Those are on 12" wide welds huh. So a 37 on 10 inch wide with 4.25 bs should be close, but guess there is only one way to find out.:D
  4. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    Here is my 6" E-Z rides with 37's at full stuff. I have no fender trimming.
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    very nice! are u running 52's or 56's in the back?
  6. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    6" and 37" boggers, but I had some trimming.
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    4" and 37s only trimming is the front fangs and rear lower quarters. I know its not 6 but it will give you another look. They are cut to the firewall now.
    Ira
  8. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Cool thanks for all the replys. Jpeater how bad do those rub during normal driving? is your axle moved forward?
  9. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    6" TCI springs 37x12.50-16 SSR on 16x10 EA589 w/ 4.5"bs
    it would rub when i would drive over a curb. it did not rub on the street though.
  10. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    did u get much rubbing with that setup?
    ive thought about running 38's w/ my 4 in lift and thought id have to trim the fenders like 2 in all around then do like u did n chop the panel below the trim on my 76
  11. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    thats sick JPEATER nice
  12. sandawgk5
    Oct 28, 2003
    6,881
    It did not rub unless I hit a curb or a large bump and then it hit hard. There was no such thing as a lite rub:D . This thread has pictures of what it looks like now.
    Ira
  13. rwright07
    Jul 30, 2005
    536
    corporate hobo
    how was it when u wheeled w/o trimming much? did it rub when u turned all the way?
    edit***
    errrr i cant see the pics in the other thread cuz i havent bought a membership... would u mind posting them in this thread like u posted the other one?
    thnks
  14. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    6" and 38's
    Only time i hit onroad was jumping a curb passing a drunk driver. I have now cut the front fangs, a little bit out of the rear fenders, and started cutting the back of the front fenders. Waiting to get the rear shaft back in so i can flex it out good and make the final cuts.
  15. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    this was before i touched my fenders, 6 inch lift with 37's
  16. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    How was it driving on the street? Looks kinda close.:wink1:
  17. sandawgk5
    Oct 28, 2003
    6,881
    If you cant see them there you wont see them here. As for wheelin it I knocked the **** out of it on the street why would I wheel it like that?
    Ira
  18. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    Pony up man, its cheap for all the info on here. This place can't make it on freeloaders.
  19. rwright07
    Jul 30, 2005
    536
    corporate hobo
    mmk how much is it? if its less then 30 il do i b4 the weekend
  20. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    membership is only 25 bucks :D
