pic request... installed np205s
Discussion in 'The Garage' started by jekbrown, Apr 18, 2006.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    As some of you may know from the 205 thread in the tech forum, I have become sort of the unofficial diseminator of scanned 205 tech articles. I would like to collect pics from anyone willing to send them of np205s installed. I think it might be useful to some people, and I have seen threads requesting pics like this before. Thus, I must have a group of them for my all encompassing 205 tech library that I email to anyone that requests it.
    So... anyone have any? Please include any stats that make sense to include... ie, if its clocked, how much, if a stock or custom x-member is used, etc etc. Ford, Dodge, GM... doubler... clocked... slip yoke, fixed yoke... divorced... doesn't matter! If its a pic of a 205 in a rig, I want it! Thanks in advance!
    j
  2. dyeager535
    26,980
    Probably not a huge help, but as I recall from one of your articles, might help to differentiate from a 203. 1991 205, VSS on the case, stock install. Can't see the fixed yoke or anything, but it's there. '85+ short, circle pattern adapter.
    Bottom one is a 465/205 combo circa 1973-84, (1974 supposedly) but mounted on an '81 frame/x-member w/ratio adapter on the speedometer cable. Tall, figure 8 style adapter, '84-
  3. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i got a few, click my sig
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    woohoo, good start... keep 'em comin' guys!
    j
  5. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    ORD Doubler setup with a GM Np203 and a GM NP205, the Doubler is configured to clock the NP205 2" up. The NP205 is a solid yoke setup using a High Angle Driveline flange for use with a CV driveshaft. The crossmember is a custom unit that I made myself, it uses a 2wd mount under the NP203 adapter and uses custom bushings that I made for under the Doubler adapter. Need more info, let me know.
    Pete.
  6. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Couple of pics of mine:
  7. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    My 205
    SM465/NP205 combo.
    Installed four days ago. (04/15/06)
    Stock set up in '85 Chevy K30.
    (except the paint)
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    sha-weet! anyone else? :thumb:
    j
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    btw, Im making sure to put ck5 screen names on the files as I save them so in the tech sharing world, everyone who contributes will be famous. :grin: :thumb:
    j
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Not my pic...
  11. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    thats purdy :D
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I know someone has more. While I'm collecting... I'm also looking for random 205 accessory pics... either factory or aftermarket. Twinsticks, billet parts, custom adapters, custom/stock output flanges/yokes... pretty much anything and everything. :thumb:
    j
  13. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    205 w/ PTO.
    Not mine, belongs to MichK5
  14. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Here's some crappy pics of mine and the crossmember I built for it. I think I am the only person to ever build a skidplate for a 205, but I figured I'd be doing quite a bit of dragging with a 130" wheel base, and I was right. The skid only hangs below the case about 1 1/2" and has been prety thoroughly beaten on rocks and dirt.
  15. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    All 32spline twinstick ready 1410 yokes International Harvester Red
    All 32spline twinstick ready round pattern
    GM to Ford clocked Doubler
    Clocked LoMax
    LoMax Guts
  16. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Heres a Klune-205 setup thats in my garage;)
    Its clocked up a few inches but not much.
    Sorry for the crappy pics, theres to much junk cluttering up the underside on this truck.
    Can you guess whos truck this is? Its getting tubed out by yours truely:D :hack:
  17. dyeager535
    26,980
    Top is a 1991 shifter from a 4L80E/205 combo, bottom is a 70's 465/205 combo.
    From what I can tell, the difference in shifter is based on the length of the transmission/adapter. Since the 32 spline 465 used longer output shafts than earlier, the +3" that was built into the adapter set the shifter back further.
    Because 1985+ 205 would have had ONLY the TH400 or 465 in front of it, and later the 4L80E, the adapters were probably designed so that the shifter was in the same location for either one, to keep from having different floor pans based on transmission, just a shifter change instead. The two shifters pictured above are definitely different as you can see. I had to bend the early one towards the driver to fit my '86 floor pan (seems like that was a fluke according to most) but the later one, even with the 3" longer adapter, bolted right in and does not hit the floor pan.
    I had never heard of the difference in shifters until I had to deal with it, so I'm not sure if there is much more documentation on this. GM COULD have used a different shifter for say a TH400/205 combo in 1981, and a TH350/205 combo form 1980 though, plus the 1985+, I just don't know.
    (copy/pasted from an old post)
  18. afroman006
    Aug 21, 2002
    2,876
    My th400/205 came out of an 88 and the shifter it has looks like the one on the top, for what its worth.
  19. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    cool pics/info... I'm clicking and saving away over here... keep it coming! :thumb:
    j
  20. Goose
    1,127
    lambertkhp, thanks. used lots of brake parts cleaner and time to clean them enough to paint.
    Some pics of the combo before install and the twin stick setup.
    Combo is from a '77 3/4 ton chevy. You can see the 10 spine output on the sm465 very well.
