Pic request of 73-75 rocker support structer thingys.
Discussion in 'The Garage' started by hawkeye649, Jul 31, 2006.
  1. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I want to go full vert. I want to see these boxes. I can't find any pix. :mad:
    Please? :bow:
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    sorry i couldn't find any pics of mine. i cut mine out & the rocker panels, then replaced them w/ a 2"x2" steal slider. mine were completely full of dirt, bet they wieghed 50 lbs each
  3. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Got pictures of your sliders?
  4. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    only ones i could find are these of them before we finished them.
  5. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    here is a finished pic
  6. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Cool, that is exactly what I wanted to see...
  7. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    no problem
    hawkeye, in those pics u can see what is left of my rocker boxes. if u imagine some heavy gauge sheet metal running from the piece near the frome to the bottum of the rocker under the door. that is about all there is to it
  8. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    did you gain ground clearence or just make more room for the sliders to be fabricated in easier? and obviously loose the 50lbs of dirt. did the body loose any rigidity? or can you even tell?
  9. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    If what I am imagining is correct, it sounds useless.
    Why did they ever go half-cab? Goobers. :screwy:
    Plus I just took the time to modify and make brackets to fit a roof-rack on my can-back. :yikes:
    I just recently destroyed my half-topper, and while I have access to 2 more, it really made me think about going full vert. But I don't like the options as far as full-vert rag tops go. Anyone ever used a can-back frame to make a full vert rag top? :doah:
    I haven't had a hard top on my truck in about 2 1/2 years, and haven't missed it 1 iota, so while I have a nice full-vert topper to throw on my rig I'm really not wanting to do so. :mad:
    Decisions suck.
  10. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Kinda hard to see, it was dark out that day. Use you photo editor to lighten it up, maybe it will help. I can't get a good pic now, they are covered up with 1/4" plate.
  11. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,836
    8
    Grand Junction, Crawlorado
    here are some
  12. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Heres a pic of mine after I had cut the actual rocker panel off
  13. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    here you go
    The back edge is the 45* line you see through the hole.
    It starts right behind the front body mount.
    Top to bottom: sill plate, what's left of the rocker and the support
    Snakes eye view
    All from the driver's side, don't mind the rust.
    here is an after, actually more like a "during", but it shows what I did on the passenger side. Drivers side was the same
    I cut the floor back 4" inboard of the outer edge of the support and welded in some 4" square tube. There is a 4" gap between the support and the floor. The support was probably .100" thick and the tube I used was 1/8" wall (.125"). Big plus was it narrowed the truck up a lot in the middle
  14. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I'm not a member, can't see those.
  15. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    They look somewhat kinda sorta like the floor supports on my 76' blazer used too. They were in good shape, I might have been able to hack those off and put them on my '90. Too bad I sent that frame to the junk yard, it was a really nice one...
    Do you guys think if I attached a piece of either angle iron or square tube, like 1/8" thick steel, a bit up the fire wall all the way under the floor and then up the 6" rise, that I should be able to get away without a roof? I have the angle iron so I'd prefer to use that if you guys think it would work.
  16. TDAWG1
    Jan 18, 2005
    2,836
    8
    Sorry I don't know how to fix that. Mine is not a 70 series its a 87 but if you go to www.Blazenoffroad.com you will see what it is or what they have anyway
