Pic Request of Hi-Steer with Hydro Assist
Discussion in 'The Garage' started by kmodi, Jan 6, 2006.
  1. kmodi
    kmodi Registered Member
    Nov 9, 2005
    56
    Atlanta GA
    I am putting hi-steer hydro assist in the truck and was curious about mounting the ram, any ideas comments or pics?
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
  3. kmodi
    Nov 9, 2005
    56
    Atlanta GA
    what is the length of the front springs you are running? how big are your bumpstops? do you have problems with the axle hitting the box?
    Thanks! these are exactly the things i need
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    45" Springs (1" longer than stock on a '72)
    Bumpstops are the standard issue from ORD, but I can't remember the length offhand.
    What "box" are you referring to? Steering box?? :dunno:
  5. kmodi
    Nov 9, 2005
    56
    Atlanta GA
    by box i meant steering box, I am going to run 52's in the front, which moves the axle forward but gives me problems with it hitting the steering box, i was just curious if you had those problems, but since you are running 45's i imagine you wouldnt.
  6. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I think I got my ram mout idea from you Greg :D
  7. 70chevybob
    70chevybob Registered Member
    Apr 25, 2004
    28
    Ada,Oklahoma
    Greg72, Does that Put a large stress on the U-bolts and Nuts? I am aslo doing the Hi-steer Ram assist and was afraid of mounting the Ram that way for fear of streessing the Nuts and U-bolts to their max. How long have you had it mounted that way? Had any problems of breaking u-bolts?
  8. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    No problems whatsoever....
    FRIZZ tends to be a little tougher on equipment than I am, so you could see how his experience has been also.
  9. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i cant think the stress would be too bad. think of how much is exerted by the sway bar!:eek1:
  10. 70chevybob
    Apr 25, 2004
    28
    Ada,Oklahoma
    Yeah, The sway bar tends to exert a bunch of stress. I was just trying to be over cautious. But With the Help of the crossover the Ram souldn't push too hard on the bolts and to cause them to break. I was just making sure before I rolled down the road. Those U-bolts are a very important part of keeping the front end together..
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I'd be a lot more worried about the center pin than the U-bolts.
  12. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
