pick up cab conversion
Discussion in 'The Garage' started by Dain Fraser, Jun 30, 2005.
  1. Dain Fraser
    Dain Fraser Registered Member
    Jun 30, 2005
    32
    Canada
    I own an 81 blazer and the rust has finally gotten to me. I replaced the rear tailpan and floor awhile back but the body is failing in other places and is getting unsafe. I would like to put a pick up cab on the frame and make it a short-short bed and I'm wondering if anyone knows whether or not a 70 chevy cab will fit the body mounts in the same way an 81-87 is supposed to.(Yes I know the rear two mounts will have to be fabricated) Any other info about the switch would be appreciated too!?
  2. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
  3. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    Yea... you can do it... trust me... set your mind to a conversion and it will happen... I've got a 54 on a 77 frame... they're a bit different haha. :p:
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Take the crossmembers out of the frame for the cab that you find.
    Any reason why you want to do this to a 67-72 cab? Those are to be cherished, not wheeled.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well yes and no, the 73-up chassis is long enough to put a pickup cab onto
    (69-72 were too short of wheelbase, 4.5" shorter than 73-up)
    i found out the hard way once
    but...
    the 67-72 body frame mount brackets are all different than 73-up
    sop you will be removing ther rivets that hold them all to the 80 something chassis and wil be swapping 67-72 ones on with 3/8" diameter bolts and nuts and washers
    chisel or grind off the rivet heads and punch the rivet bodies out
    stash the 80 soem brackets away in a box in the attic labeled with a marker
    all your wiring and front clip and everything youll be converting to 67-72
    and fuel line routing and carb linkage and so forth
    personally i wouldnt do it, but i would with a 73-up cab
    good luck
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so how much of the pickup bed would u have to shave off in order for it to work?
  7. Dain Fraser
    Jun 30, 2005
    32
    Canada
    Thanks all for the input. The reason I wanted to go with a '70 cab was because I had a line on one in good condition, front clip included.
