picked up this beast on monday
Discussion in 'The Garage' started by ChickenRammit, Jul 27, 2006.
  1. ChickenRammit
    ChickenRammit 1/2 ton status GMOTM Winner
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    dana 60 from an '88 drw k30. it came with 4.10 gears. i was wondering if the 10bolt brake calipers fit the d60 knuckles because it had no calipers on it.
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    No, not without an aftermarket kit. The D60 uses the bigger Bendix calipers...
    Rene
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Get 2 of these and you can.
    Caliper Brackets
    There is a company that makes these brackets that you can also run 15" wheels without grinding. I am not sure if those are the link or not. Also try Gravelmaker on here he is a vendor I think he makes brackets like that.
    Ira
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    welcome to the 1 ton club :D
    I doubt it. but you could get some 3/4 ton brackets from screamin seeman offroad. and then use your old brake setup from your front 10b that's on your rig now. I did the swap last month. the reason I went with the conversion was I had the parts already from my 10 bolt that were in great shape. and I needed new calipers and rotors for my dana 60 so it was cheaper to go this route. plus the wedge style caliper mounting system is a huge PITA!!!
  5. ChickenRammit
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    if i was to run the h1 rims to i then need to look for a 14bff that is also from a dually to get the widths to be the same front and back?
  6. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    14FF from a dually is narrower than normal, you need a single wheel 14FF and some wheel spacers 4" IIRC
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Or the wider D70HD rear. :wink1:
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    From your pics and Ira's, we can clearly see how the caliper fits the rotor utilizing a bent bracket where as the one that Ira shows on the link is just a flat bracket.
    What is the deal here? If the flat brackets are used, which rotors are employed? Looks like the SS brackets use the standard GM 3/4 ton rotors. Don't know how those can fit to a flat bracket like those from Extreme Axle Sales.
  9. sandawgk5
    Oct 28, 2003
    6,881
    Did not even notice that. I would go with the bent brackets as there are pics that show they actually fit:D . I am thinking about doing this cause I think I have a bad caliper and I dont wanna grind D60 calipers again:doah: .
    Ira
  10. ChickenRammit
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    is there any difference between 1/2 ton and 3/4 ton calipers and rotors on the 10 bolt frontends?
  11. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    pretty sure the the caipers are the same. the rotors are different.
  12. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    yup 1/2 ton rotors are 6 lug and 3/4 rotors are 8 lug. half ton rotors will not fit on a standard D60 hub
  13. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    are you using the 10b wheel studs (7/16) as well? they look small compared to the 9/16th. looks good tho
  14. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    nope, 1 ton studs. I had to drill out the rotors.
  15. ChickenRammit
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    looks like this is the route i am going to take. how well does 10 bolt brake equipment perform on your beast? i like this setup because i can stick with 15" rims without grinding the calipers. seems to me that when the rims get bigger than 15", tires start getting real expensive.
  16. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    works great on my sub. I also have rear disc brakes. I Need to have the brake system powerbled there alittle soft but they stop great. hit them up on pirate so u get them for $75 to your door. oh yeah there instructions says to drill out the rotors to 21/31 which is not right u need to drill them out to 11/16.
