picking a comp cam for the 383
Discussion in 'The Garage' started by 55Willy, Aug 1, 2005.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'm looking at either the 262X with .462/.480 lift or the 274X with .487/.490 lift model.
    I'm running dart iron eagles, with roller rockers.
    main use is towing,
    remind you this is going in a 2 ton burb with 35's and 3.73's
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    The XE274H is the wrong cam for a 383 with 5.7" rods in a 2 ton tow truck,
    that combination has a short rod ratio of 1.52:1 and is not comfy revving over 5500 rpm...........the 274 doesn't start making power until 1800 rpm.
    you want a cam that compliments the high-torque, short-rev personality of long-stroke, short-rod motor, choose a cam that pulls clean right of idle to 5500 rpm........try to keep the LSA at or below 110 degrees and use 1.6:1 rockers to bump the lift.
    I run a XE274H and it has a chop that my wife compares to a helicopter.....
    she's a little pissed because the truck is too fast for her to drive now.
    damn baby.........I'm sorry :haha:
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I have the 274 in my 383. With aluminum heads, RPM Air Gap intake, blah, blah, blah. Tho I dont really tow much. I would go for the smaller cam for a heavy tow vehicle. The thing is loud, choppy idle and has a gear drive. Definatelly hear it coming!! Right now it has 4.1 gears with 35" tires. Im thinking some 38's would be good. But first I have to fix a hard brake pedal and get the thing to stop throwing the power steering belt. :wink1:
  4. Indyblazer
    Indyblazer Registered Member
    Apr 24, 2005
    35
    Indiana
    Ask the Experts
    When I built my 406 cube SB Chevy I had the very same question. I had spent BIG $$$ and wanted to get the best performance. I called the Tech Dept at Comp Cams. They are Terrific !! You need to have ALL the specifications about the engine AND the vehicle. Transmission gears, rear gears, vehicle weight, engine specs including carb/injection pistons, rods, valve sizes, cylinder head specs (valve & port sizes, Flow & CFM numbers etc)
    Go with what they recommend!!!
