pickup cab blazer frame
Discussion in 'The Garage' started by tomford, Jan 17, 2007.
  1. tomford
    tomford 1/2 ton status Premium Member
    Jan 19, 2006
    921
    7
    New Hampshire
    i know ive seen pics here before but i wasent sure what to search. What needs to be done to run a pickup cab on a blazer frame? will it line up or what
    thanks for the info
    tom ford
  2. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    Trazzzzer
    What year is the Blazer frame? I'm in the process of putting a 82 cab on a 85 blazer frame. The front cab mounts are the same you just need to fab up a crossmember for the rear cab mounts. Many have used the factory truck crossmemeber and raised it up with some home made brackets. I chose to build an entire crossmember and will later tie the rear cab mounts into the rollbar/rear cage. Here is my build link on my Clubs site.. the pic only shows half my crossmember because its not installed yet.
    http://georgiatrailrunners.com/bb/viewtopic.php?t=1446
  3. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
  4. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i went with the origional mounts.here are some pics,sorry it was dark and scary outside.:haha: :haha: i didn't measure them tonight. if you want to go that route i will for ya.:D i aimed blindly with the cam
  5. boggerless
    May 26, 2003
    22,728
    96
    don't pay attention to the bungie cord exaust straps.i'll have the flow masters on by spring. HA HA HA
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    If memory serves the older blazer frames, in the 70's are a direct bolt on. I did the swap and don't remember any issues at all. It was also a 70's, mid to late, cab.
  7. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Yea for an 80's frame your going to need to fab up something for the rear crossmember, but its pretty easy. I used the crossmember from a pickup truck and cut some plates that were welded on top of the frame and then the crossmember bolted to them.
    The front mounts line right up. Big Dan posted the link to my body swap thread so you can see pictures there. I made to sure to get a lot of close-ups because I know there are a lot of people that want to do this.
