pickups with body lifts/gas tanks
Discussion in 'The Garage' started by original balzer, Nov 22, 2005.
  1. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    those of you that have 3" body lift on your pickup. did you raise the gas tanks as well? is there room to add a 3rd k5 tank to the back of the frame without it hanging down? anyone put a gas tank in the middle of the frame in front of the rear axle?
    balzer
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    The previous owner put in the body lift. The truck only has 1 16 gallon saddle bag tank, and he relocated the tank to the other side and put in a rubber hose for the filler that runs to the other side. (The Tank is on the passenger side, the filler is on the driver side, and there's a good sized hose that runs between the frame & body to connect the 2
    I'm looking at putting a suburban tank into it and ditching the saddle bag. I need more than 16 gals on the trail w/ a thristy 383 :eek1: I have to carry 3-5 gallon jerry cans and fill up through out the day.
    Mike
  3. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    blazer / burban tanks will fit in the c/k truck frames. easy to make mounts . but need to put in the back side of axle. and if short bed best go just 31 gal only to keep it short .
